My 1994 Acura Integra Turns off Randomly when I'm driving .??
I have a 1994 Integra LS 5 speed.. 158xxx miles . Withing the last month or so til now it has randomly turned off on me 6 times with no warning. I'll be on the freeway going 80.. then my power steering stops working the miles start dropping and sometimes the check engine,battery & oil light comes on when it happens. It just turns Off. So I pull to the side and when I try to start it back up it sounds as if I don't have any gas even though I do.. Like it makes the sputtering sound like your trying to turn on a car with no gas.. And sometimes it just randomly won't turn on either. I can't have this keep happening to me. I mess with it then let it sit a min try again then let it sit some more.. then about 15-25 minutes later it turns on absolutely normal like nothing ever happened.. wth I need help >_<
Most common problem is the PGM-FI Main Relay.
Without clearer info on exactly what happens it is the first thing I would check, you will of have to wait untill it fails again, when it does, turn the ign. switch on to the run position, [NOT start]...
Does the cluster light up, [gauges, oil and CEL lights and so on] do you hear the fuel pump priming?
http://techauto.awardspace.com/mainrelay.html
http://www.tegger.com/hondafaq/mainrelay.html
Let me know what you find/hear. 94
You should disconnect the main relay, and take the circuit board out of the casing, inspect the circuit board for any cracks where the solder is. ANY CRACK AT ALL CAN CAUSE AN INTERMITTENT PROBLEM. Let us know what u find. U may be able to just re solder the end and fix it.
The PGM-FI Main Relay is a cheap part to replace. This is a common problem in older hondas (they are getting into their 20's!!). Hondapartsunlimited.com has them for about $47 (39400-S10-003) If I picked out the right part.
-Alex
-Alex
-Alex
I've had a few intermittent. Usually if the car dies and if you let it sit and it'll crank back up the ignitor is to blame, if it doesn't crank back up usually the coil is bad. I've never had a stall condition with the main relay, mostly a hot day no start or short drive and then a no start. I'm not saying it couldn't happen just saying I've never had that happen to me.
