1998 Phoenix Yellow EK9
For Sale:
1998 Honda Civic Hatchback DX
Phoenix Yellow/Sunlight Yellow Paint Less Than 2 Years Old
Shaved Antenna and Rear Emblem Hole
1998 Integra GSR Engine ODB-2A
OEM motor, never been taken apart expect for valve adjustment
Runs strong and pulls hard
BAR referee sticker since 2008
Pink Slip To Provide Legit Motor
Power Steering
Air Conditioning (Removed, but lines are still in there for reinstallation)
Power Door Locks (OEM wiring, harness, actuators, regulators, etc from 2000 Civic)
Power Windows (" ")
Rear Windshield Wiper (Great for quick defrosting)
Approximately 120k miles on the engine pulled from a wreck GSR that a family member owned
major tune up including but not limited to valve adjustment, timing belt, all accesory belts, belt tensioner, water pump, oil pump, rear main seal, oil pan gasket, valve cover gasket, spark plug gaskets, spark plugs (NGK Iridium Plugs), spark plug wires (NGK Blue), and Differential Bearings.
JDM ITR ECU (GSR currently to pass smog, ITR ECU will be swapped in after purchase)
Exedy Stage 1 Clutch (20k)
GSR Transmission
ITR Limited Slip Differiental
CTR Throttle Body
Skunk2 Intake Manifold
DC Sports JDM 4-1 header 2.5 inch Collector
Custom 2.5 inch Race Pipe
APEXi World Sports 2 Exhaust
Comptech Intake with Ice Box
OEM GSR Header
OEM Catalytic Convertor
Visteon (C&R Racing) Radiator
SPAL Slim Fan
Tein Flex Coilovers 10K Front 7K Rear Spring Rate (1 year old)
CTR Front Lower Control Arms (one piece design)
CTR 26mm Front Sway Bar
Genuine ASR Rear Subframe Brace
CTR 22MM Rear Sway Bar
Cusco Aluminum Front Strut Bar
Cusco Carbon Fiber Rear Strut Bar
Rota Slipstreams 15x7 +40mm 4x100
Bridgestone RE-11 205/50/R15 Tires 30% Life
ITR Front Calipers on 4x100 Hub
11 inch Brembo Front Blank Rotors Redrilled to 4x100
Hawk Performance Plus Brake Pads all around
ATE Super Racing Blue Brake Fluid
Genuine CTR 00/99 Bumper
Genuine CTR 00/99 Front Lip
Genuine CTR 00/99 Headlights
Genuine CTR 00/99 Fenders
Genuine CTR 00/99 Amber Side Markers
Genuine CTR 00/99 Hood
Genuine CTR 00/99 Rear Wing
Genuine CTR 00/99 Rear Lip
Genuine CTR 00/99 Thin Side Moldings
Fenders front and rear rolled with a slight pull in front (before paint)
Painted Bumper License Plate Hole Covers
Keyless Sedan Rear Door Handles
Civic SI 00/99 Climate Control Conversion
Civic SI 00/99 Cluster
Civic SI 99/00 Armrest
MOMO Steering wheel Hub
MOMO Monte Carlo 360mm
Recaro Speed Passener Side Black With Red Stitching
Vision Super Low Seat Rail
Recaro SPG Driver Side Seat
Buddy Club Seat Rail
Moogen Pedal Set
CTR Red Carpet
CTR Shift Boot
ITR Shift ****
OEM Honda Windows all around
PPG replacement windshield
Viper 5900 2way Paging Alarm with remote start
Alpine IDA-305S Pandora streaming, iPhone charging and playback
Alpine 6.5 Type-S Component Speakers
Alpine 6x9 2 Way Coxial Speakers
Alpine F300 4 Way Amplifier
asking for $8000
PM a number for fastest response.
Power Steering
Power Windows (" ")
GSR Transmission
CTR Throttle Body
OEM GSR Header
SPAL Slim Fan
Moogen Pedal Set
CTR Red Carpet
CTR Shift Boot
ITR Shift ****
asking for $8000
Bump for MORE detailed pics.
engine compartment, interior.
Looks good on the outside, but you need to show the whole package to justify your asking price.
It would eliminate the tire kickers from the serious buyers knowing the car is all that you say it is.
