97 accord issues
Old May 17, 2012 | 02:14 PM
CD6fodoh's Avatar
Default 97 accord issues
So I own a 97 accord lx 4-cylinder and when I turn my steering wheel it squeal or make a weird noise. I have been told it could be ball joints or struts I really don't know what it can be but I'm trying to get it fix ASAP. Thanks Honda Tech in advance.
Old May 17, 2012 | 05:06 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 97 accord issues
Does it make the noise if the engine is on or off?
If only when the engine is on, is there enough ps fluid in the reservoir?
Need more details as we cannot see/hear the car.
Old May 18, 2012 | 04:33 AM
CD6fodoh's Avatar
Well when the engine is off I'll turn my steering wheel from left to right it'll make the noise and when it's on and running it makes the same noise in motion. I jacked my car up and moved the steering wheel from left to right it didn't make a noise at all.
Old May 19, 2012 | 07:00 AM
CD6fodoh's Avatar
bump help?
Old May 19, 2012 | 06:38 PM
MAD_MIKE's Avatar
MM Gruppe B
bump help?
Get a second person to turn the steering wheel while you walk around the front of the car and try to pinpoint the noise. You can also try jacking up one side of the car at a time and see if the noise only happens with both or just one side on the ground.
Old May 21, 2012 | 04:39 AM
CD6fodoh's Avatar
Yes I tried it. The noise was coming out the driver side only. But when it's jacked up there's no noise when the steering wheel is turned but when it's off the jack it makes noise
Old May 22, 2012 | 05:28 PM
Lost Again's Avatar
Under load, really sounds like a ball joint binding.
Old May 25, 2012 | 08:23 AM
CD6fodoh's Avatar
So lately I been trying to pin poi t the noise with someone moving my steering wheel seems to me it's coming from the bottom not upper ball joint by any chance it could be my lower ball joints ?
Old May 27, 2012 | 03:44 AM
Lost Again's Avatar
Yes, I don't think anyone ever said it was the upper, just that it sounded like a ball joint issue.
ApatheticAccord
Mar 12, 2016 01:48 PM
iiPancho
Jan 13, 2009 01:54 PM
djdownfawl
Mar 26, 2008 08:24 PM
