Nasty gunk around my axle
Old May 17, 2012 | 08:25 AM
wgbm92's Avatar
Default Nasty gunk around my axle
The title says it all. I would like to add that about a year ago I had my axles replaced, and when the transmission fluid was replaced, they used motor oil instead of manual transmission fluid. I have a strong feeling that it has something to do with the nasty gunk that you see in the video, but I'll let someone else be the judge of that. Also, I had just bled the clutch out a few days ago, but I don't think that's relevant to this. The gunk looks like it's been sitting there for some time now.
Old May 17, 2012 | 08:50 AM
Arthas's Avatar
Default Re: Nasty gunk around my axle
Are you sure thats not the grease left over from your old axles? When I replaced my axles I left the old great on there, it didnt bother me.
Also, switch out your transmission fluid with Honda MTF ASAP. Itll be the best $20 you ever spend!
Old May 17, 2012 | 09:00 AM
wgbm92's Avatar
I'm positive it's not from the old axles. All of the oil that came out from the old axle dripped down. I remember that we even wiped off the excess oil from around the axle inlet. The gunk that's there now is all around the axle; bottom, sides, and above it. But yes, I will definitely stop by the dealer to pick up some Honda MTF
Old May 17, 2012 | 09:04 AM
Arthas's Avatar
Axles dont have oil they have grease.
Old May 17, 2012 | 09:35 AM
wgbm92's Avatar
Oil, grease; potato, potatoh, you know what I mean. They're both lubricants, and I was referring to the MTF that was coming of the tranny when I pulled the axle out.
Old May 17, 2012 | 09:42 AM
1991civiclx13's Avatar
so what are we looking at in your video, grease or oil...
Old May 17, 2012 | 11:08 AM
dpetro1's Avatar
grease it spraying out of the boot. either the boot is torn or the band clamp isnt tight enough.
Old May 17, 2012 | 12:09 PM
wgbm92's Avatar
You're looking at all of the grease that's all over the tranny and around the axle, and anything else that doesn't look right.
Old May 17, 2012 | 12:48 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Get a replacement axle or change the metal strap on the axle, you better get MTF fluid for your tranny before it's kaput
Vagitarian
17
Aug 3, 2012 08:45 AM
ILLICON3000
Dec 20, 2004 12:50 PM
b18bfreak
Aug 2, 2004 10:05 AM
EVIL_AWD
May 24, 2003 06:04 PM
qwklude82
Jan 4, 2003 04:47 AM
