Getting the best fuel economy - manual transmission?
Old May 16, 2012 | 12:38 PM
gnarlycs's Avatar
Default Getting the best fuel economy - manual transmission?
What are some tips for getting the most out of every drop of gasoline with a manual transmission car? I've heard that the throttle position is more important than engine RPM. Which one is a bigger factor (and by how much) in fuel consumption?
Old May 16, 2012 | 02:22 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Getting the best fuel economy - manual transmission?
Hypermiling. Look it up.
Old May 16, 2012 | 03:01 PM
TunerN00b's Avatar
Throttle position is usually a bigger factor than RPM, but as with most things, it is very specific to the engine and car being discussed.
Meaning, we really can't go into too many generalities other than the typical hypermiling techniques.
However, the biggest change most people can make is to coast. Your average idiot driver stays on the gas until they need to brake to come to a stop. Don't be that idiot. Coast, in gear, from cruising speed until you approach idle, then put it in neutral (ideally, you'd do this right before the idle circuit kicks in, which is 1,400 RPM for my car). If you do it right, the car will stop on it's own without brakes, and you'll have saved the most gas possible.
Old May 16, 2012 | 03:48 PM
civickiller's Avatar
i run my car a little leaner around 1 point leaner for partial
i got 35 city 38 highway lsv b16 trans
eL
Honda Fit
369
Jan 19, 2019 10:55 AM
dleccord
11
Dec 27, 2009 11:19 PM
pooMan
Aug 25, 2005 12:20 PM
pooMan
Aug 25, 2005 11:40 AM
ArchAngel Sabastian
Aug 25, 2001 11:34 AM
