Broken Bolt in inside intake 16 cam seal H23a
So I was leaking oil out of the intake cam where the rubber seal is on the outside of the head. It needed silicone. When I put on the cam seal 16(each seal is labeled with a number...) the inner bolt broke off from me over tightening it.
1. What is the best possible fix? Would I drill out the remainder of the bolt and re tap it?
2. How bad is it that I drive to work with the bolt like that? I will probably to go a mechanic in he morning.
3. My cat is also missing. Does anyone know where he is? This has been a truly horrific day.
Any help would greatly be appreciated.
I think you misunderstood what I was trying to convey, but I alredy fixed it. The mechanic told me the best thing to do would be to re tap it. It's already fixed but thank you. For you're future reference a bolt that is broken that holds down the cams wouldn't have any where to leak out.
No man, he's gone. He was such a cool guy too. He would always help me when I was working on my vehicles. He would sit up on the hood while I was wrenching on the engines or hang out inside the car if I was cleaning it. Hard to replace his personality with a better one.
cadwiese
24
May 19, 2010 05:58 PM
