Fuel/Gas Leak help
Old May 15, 2012 | 09:04 PM
BIGef's Avatar
Default Fuel/Gas Leak help
89 Civic hatchback Dx
Its been sitting for one day havent drove it. Then next morning i smell fuel around my car. Popped the hood nothing. Went under the car i saw a leak dripping non stop. Not a lot though. I dont know where is the leak coming from but its not from my tank.If anyone know where this should be leaking due to i have no jack or tools with me right now. Car is dropped cant go under. If anyone can give me a diagram of the part. thanks
FROM THE DRIVER SIDE
Old May 16, 2012 | 05:55 AM
BIGef's Avatar
Default Re: Fuel/Gas Leak help
Just found out that its one of my fuel lines thats coming from under the rear seats. Tried playing with it and its spraying fuel. and this fuel line has a rubber around it. anyone know how to fix this? can i just patch it up? or have to replace the fuel line.
this is my daily commuter need this fix asap
Old May 16, 2012 | 06:01 AM
Taiperas's Avatar
try to remove the plastic wrap, dry the line out and apply some cold weld on it. should fix it at least temporarily. the best solution is to change the line or only some of it using a new line (this will need a special tool to connect the lines)
Old May 16, 2012 | 08:02 AM
BIGef's Avatar
yeah i remove the plastic wrap from it. it was a line that was leaking. Its a steel line then it meets to a hard rubber line. Thats where it leaks. The line is leading inside the rear seat to the bay.
Old May 17, 2012 | 05:53 PM
BIGef's Avatar
Well i still need help. I kept playing with the rusted hose and it just broke off. Took the nut off on the hose. Went to almost to every auto store i can find to find this nut but cant seem to find it here. I was gonna convert the rusted part to steel braided hose. Anyone know where or i can find this part??????
blue=part of the hose inside the car connecting to the bottom
green=rusted part that cracked]
red=nut that i cant find anywhere
Old May 17, 2012 | 07:01 PM
copy's Avatar
Don't smoke or use any open flame if there is gas in the lines.
Gas is flammable as well as explosive and is a hazard if it catches fire !
Old May 17, 2012 | 07:11 PM
BIGef's Avatar
i dont smoke or anything. i dont drive nor i will not drive it till its fixed.
Ty05
Sep 22, 2009 08:38 AM
Spectrum24x
May 1, 2008 08:09 PM
-Bionic-
Oct 26, 2005 09:16 PM
Whig-it
Aug 26, 2004 07:51 PM
LBR92DA-T
Oct 25, 2003 02:21 AM
