SFWD part out everything's new 1000hp set up
Hey parting out my SFWD car everything is new and prieces are FIRM posting from my phone so will have to text you picuters thank you
$3500 for block
$1500 for head
B18c w/Darten sleeves 84.5 bore
Carrillo Rods w/bolts 1200hp rods
CP 9:7:1 pistons w/upgraded wrist pins
ITR oem oil pump
ITR oem water pump
Morso oil pick up*
Morso oil pan
ACL bearings
Powered coated water tube and neck
Every nut and bolt brand new from Honda*
B18c5 head stamped by RLZ*
3 angle valve job*
Port and polished*
Supertech valve train*
Oem seals*
Ferria valves*
Skunk2 stage 1 cam*
Skunk2 cam gears*
$3500 for block
$1500 for head
ITR oem oil pump
ITR oem water pump
Morso oil pick up*
Morso oil pan
ACL bearings
3 angle valve job*
Port and polished*
Oem seals*
Ferria valves*
Skunk2 stage 1 cam*
Skunk2 cam gears*
Bump for good price and killer setup!
Similar to my setup but I'm using dart block RHS head.
Any chance on parting with the fluidamper?
DC2Mex
Nov 24, 2015 03:01 PM
cl3an_98gsr
15
Jan 7, 2010 04:52 PM
User 42624
May 1, 2006 09:32 PM
