Push Start with EFI?
Old May 14, 2012 | 03:33 PM
Shortyluvsu2808's Avatar
Default Push Start with EFI?
Is it still possible to push start a car with a manual trans even though it has Electronic Fuel Injection?
Old May 14, 2012 | 08:14 PM
Gunmetal_B20_Hatch's Avatar
Default Re: Push Start with EFI?
yes... as long as the key on in the "on" position and you have a small charge in the battery
Old May 15, 2012 | 07:37 PM
uberEFtuner's Avatar
Yes have the key in the run position. Then push the car as fast as possible or coast down a hill. then put in in 1st and dump the clutch. The car will buck, and start.
You do not need any charge in the battery. If the battery is dead it will start easier, if you disconnect the battery.
Old May 16, 2012 | 06:23 AM
Muckman's Avatar
Moderator in Chief
You've never seen or heard of anybody push starting a car that is newer than 35 years old?
Old May 16, 2012 | 06:37 AM
kyden's Avatar
i've done it plenty of times. dead battery, no other car around or jump pack available.
Old May 16, 2012 | 06:56 AM
OD's Avatar
OD
yes you do.
Old May 16, 2012 | 08:19 AM
no...
http://en.wikipedia.org/wiki/Push_start
If the vehicle's battery is severely discharged, the push starting technique can be unsuccessful, as the battery may not be able to provide sufficient voltage for the ignition system to function (or in the case of a diesel engine, to preheat the glow plugs, although this will not generally prevent starting altogether but just make it much more difficult). Also vehicles with an electronic engine management system will not start if the battery does not provide sufficient voltage to operate it. In such cases, recharging the battery or attempting a jump start is a better option.
NiKKa NiKKy
Jun 30, 2022 09:59 PM
bak lee
Sep 16, 2011 02:03 PM
hackykid
Aug 8, 2007 11:16 PM
MooreBoost
Aug 31, 2005 08:53 PM
