What should be my corrected EGT if....?
Old Oct 13, 2002 | 02:58 PM
AlphaKennyWun's Avatar
Default What should be my corrected EGT if....?
...my probe is right after the downpipe but before O2 sensor? Keep in mind I need the corrected temperature because Right now it doesnt go higher than 1000-1100F.
Old Oct 13, 2002 | 03:19 PM
Jared's Avatar
Default Re: What should be my corrected EGT if....? (SO3Burner)
move the probe, it should be on the #3 cylinder and the distance from the head should be half the diameter of the pipe(for example, if the primary off the head is 1.5" then the probe would be .75" from the head)
[Modified by Jared, 2:10 AM 10/14/2002]
Old Oct 13, 2002 | 03:27 PM
BoostedED9's Avatar
Default Re: What should be my corrected EGT if....? (Jared)
should hve the probe before the turbo
Old Oct 13, 2002 | 04:42 PM
ion_four's Avatar
Default Re: What should be my corrected EGT if....? (ED9Hybrid)
there is no way for someone to guess what the corrected value is. it could be anywhere from 100-500 degrees, depending on exactly how far from the turbo. The way to use the egt, apparently, is to get your car dyno tuned and then if the egt's stay at those same levels; your car is still tuned properly. if they change; something is wrong.
Mine is in the 3rd runner on the manifold and I don't think it's ever gone over 1500 and rarely over 1400 with stock timing and running VERY rich. cruising is 900-1100, depending on rpm and load.
oneludesol
Engine Management and Tuning
Oct 22, 2009 02:31 PM
oneludesol
Oct 5, 2009 12:51 PM
alexsracing
Jun 14, 2005 07:18 PM
Blindstuff
Jun 2, 2004 09:51 AM
SupraDai
May 14, 2004 07:56 PM
