90 CRX DX Wont Start/Stalls
Old May 14, 2012 | 12:20 PM
journeyquest's Avatar
Default 90 CRX DX Wont Start/Stalls
Problem started a couple weeks ago. Sometimes wont start. Sometimes stalls. When it starts, it runs fine. Seems to be worse when its warm out. Yesterday when it was 90 degrees out it wouldnt start no matter how long i cranked it. Last night when it was cool out, it started right up and ran fine. Does this sound like the main relay? When it did start i thought i smelled a slight burnt smell.
Old May 14, 2012 | 12:25 PM
Dc4LsTeG's Avatar
EK9
Default Re: 90 CRX DX Wont Start/Stalls
Have you checked your main relay?
Old May 19, 2012 | 03:04 PM
CRXcaliber's Avatar
Definitely the main relay. My 91 DX had the same problem when I bought it and I had to fix it where it sat to leave with it. Took me two days to figure it out, lol. Don't know if you have had experience changing one but be ready for about a good hour or two of cussing. Lie down in the drivers seat looking up under your dash. If you look at your hood release and follow a line pretty much straight up the side of the body you will see it waaaaay up in there (Probably about as high as the gauges or just below). Thank God it has only one bolt which is easily reached with some extensions and a universal or two. Getting it loose isn't really the problem although it will take a bit. The problem is that there is not really a hole big enough to get the damn thing out of so you can unplug it and switch or repair it. You WILL have to take a couple things loose and pull stuff to the side, trust me. I wasted about half an hour being stubborn even after I was told the same thing trying to find an alternate way without taking stuff loose. You can either buy a new one for 40 to 60 bucks depending where you get it. Don't buy a used one!!! They usually go bad at the solder joints where the coil is on the board from vibration, heat, etc... That's why it won't crank when it gets hot. The joints expand and break contact. One quick way to tell is an old electronics trick I used when I did bench work repairing TV's and stuff: Get a can of cold spray at Radio Shack or wherever and spray the crap out of the box until its good and frosty (It comes with a tube like WD40). Try to crank your car. If that is the problem it can be soldered back but I just bought a new one. I am gonna take my old one and try to fix it when I get a chance, just to have a spare. I'll let you know how that goes when I do. Never really looked to see how hard to get it apart and stuff I was in a hurry and just bought one cause I didn't have the stuff to repair it with me anyway.
Old May 19, 2012 | 03:19 PM
Thanks, i work at Metro Auto and will get a good discount on parts. Most likely half price. Havent got around, but will get someone to fix it since i have a bad back.
Old May 19, 2012 | 07:46 PM
monstermax's Avatar
sounds like the fuel pump relay... its like 50.99 from autozone. bought one like 2 weeks ago. same problem on a 90 ef hatch. fixed it
Old Jun 26, 2012 | 12:53 PM
Main relay didnt fix problem. Took it to mechanic. He checked fuel pressure and injectors. He said they are good. He is still trying to figure it out. He had it running good for 20 minutes then it wouldnt start. Intermittant problem. Seems like an electrical problem. ECU? Damn car only has 80k miles and has been sitting more than running since i bought it.
Old Jun 26, 2012 | 01:52 PM
singlecamsaint's Avatar
check the ignitor inside the distributor, maybe the heat is causing the circuit to open
Old Jul 29, 2012 | 10:25 PM
It was the ignition module inside the dist. Even though the distributor only has less than 200 miles since new.
Evil-Mpire
Jul 13, 2009 05:08 PM
1slowSIrex
Jul 24, 2006 10:07 PM
Slow as piss
Oct 4, 2005 02:10 PM
tboss
Sep 26, 2003 06:30 AM
SpeedMonkeyRacing
Jul 30, 2003 06:15 PM
