Will front knuckles from 98 civic ex bolt directly onto 92 civic dx hatch?
Old May 14, 2012 | 10:39 AM
92SleeperDX's Avatar
Icon2 Will front knuckles from 98 civic ex bolt directly onto 92 civic dx hatch?
Hello,
Question.... Will the front knuckles from a 1998 civic ex bolt directly onto my 1992 civic dx hatch? I've got the rear disc assembly from a 1995 integra already, but the front is my issue now. I understand that I will need new master cylinder and proportioning valve and brake booster as well.
If it helps answer my question too I'm having a new engine/tranny installed. Im getting a b18c from HMO with the complete swap, axles and all. Not sure if the B series axle will make a difference when I'm trying to do my brake swap.. Logically to me it seems as though using 1998 civic ex knuckles should work. I've never done this before so your incite will help.
THANKS
Old May 14, 2012 | 11:42 AM
Former User's Avatar
Default Re: Will front knuckles from 98 civic ex bolt directly onto 92 civic dx hatch?
Please place simple technical questions directly into the thread title -- Title edited.
Old May 14, 2012 | 06:28 PM
DSMAddicted's Avatar
Yes, the 96-00 EX front knuckles are the same as the Integra ones (IIRC).
They are an upgrade for our 92-95 Hatches.
You'll need to run at least 14" wheels with those, though.
Good luck.
Old May 14, 2012 | 07:36 PM
Hey thanks guys for the info... Im running the 15in rotas so Ill be all good... thanks again!!
Old May 15, 2012 | 06:12 AM
kyden's Avatar
the geometry on the 96-00 civic knuckles are different than the integra. it'll change your caster.
Old May 21, 2012 | 01:12 PM
caster as far as I know being a noob has do do with alignment. if I use these parts what would you suggest i do to fix the caster problem? thanks
Old May 22, 2012 | 02:55 AM
jbpnoman's Avatar
Caster, Camber, and Toe. Those are your three alignment specs. Caster does have something to do with your alignment, but it primarily affects bump steer. Caster is non-adjustable in 92-00 Civics.
Old May 22, 2012 | 07:38 PM
So no go on this set of brakes/knuckle will look for integra brakes now i suppose
Old May 23, 2012 | 06:19 AM
I think they're still fine.
Forwarding this thread to a couple of people that ought to be able to safely confirm.
Old May 23, 2012 | 06:26 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I know the front upper control arms differ from 92-95 and 96-00 models, so I'm assuming the knuckles might be different geometry wise.
I can only tell you with 100% certainty that 94-01 Integra knuckles work 100%.
Not sure about 96-00 ones man, sorry.
Old May 27, 2012 | 08:38 AM
Its all good I just ended up calling HMO and buying the Integra swap from them.. Took a hit on the 98 option but oh well..
98ej1h22
Apr 13, 2014 08:21 PM
viciousvisionslarry
Sep 28, 2004 05:33 PM
yusoslo
Aug 30, 2004 12:49 PM
