CB7 H22A Sounds clogged?
Old May 13, 2012 | 10:50 PM
H22_CB7_JAY's Avatar
Default CB7 H22A Sounds clogged?
Okay,
h22a CB7 (1991 ACCORD)
So Ive been noticing more and more lately that my car is starting to sound clogged up, or restricted somewhere.. This occurs both when the car is warm, and when its cold (more so when its cold, getting a little better when its at operating temperature.), Can someone suggest to me what could be the problem? My cat looks pretty old, but I highly doubt its clogged.. When I first got the car I seafoamed the motor, could this have clogged maybe the cat more? I changed the EGR valve thinking that it was gonna be horrid when I took it off, it really wasn't that bad.. and it runs alot better but this issue still occurs. The car will run ABSOLUTELY SOLID at times, and this problem will not occur. My idle will hold at 1,000 even and sometimes DROP almost dieing and idle very oddly, and run clogged up (it seems)..
Old May 13, 2012 | 11:09 PM
katzenjammer84's Avatar
Default Re: CB7 H22A Sounds clogged?
If it's the original cat, there's a very good chance that it can be causing some problems at this point.
Without a check engine light code though, this is very hard to diagnose on the internet.
Old May 21, 2012 | 08:47 PM
ocdp310's Avatar
But the exhaust note changes? Is this at idle or while driving around?
NeedmoPowr
Oct 28, 2014 06:15 PM
Jacob VanMeter
Nov 1, 2010 09:49 AM
UPYOURZ
Dec 17, 2005 09:53 AM
kholmes
Mar 17, 2005 12:57 AM
