vtec vs non vtec dizzy looks same
Old May 13, 2012 | 09:21 PM
raverx3m's Avatar
Default vtec vs non vtec dizzy looks same
so while trying to fix my p30 dizzy because the remanufactured dizzy sucks i found out that all of them seem to be identical besides the actual casting.
i have 4 distributors 2 p30 and 2 p06
all 4 are obd1
i took 2 of them completely apart and inside they are all identical.
even the stamps on main shaft are same ( all say p06) same amount of teeth. same mounting position of the snail shell shaped part.
then i go read online and it says they are 180 degrees off because the snail part mounts differently. well ll 4 of mine are mounted the same way vtec and non vtec.
am i missing something?
UPDATE.
TD-41U
TD-42U
TD-44U
TD-44U
REMANUFACTURED DIZZY for DOHC VTEC
i inspected all 5 distributors while they were off the car.
side by side comparison shows that internally they are all identical.
the only difference is the casing
P30 casing rotates dizzy by 90 degrees it seems, compared to sohc vtec dizzy
now my photobucket is not working for some reason... ill upload pictures soon
Old May 16, 2012 | 06:32 AM
Muckman's Avatar
Moderator in Chief
Default Re: vtec vs non vtec dizzy looks same
AFAIK the snail shapped trigger is different and will misread cam position.
http://www.d-series.org/forums/gener...th-busted.html
If you are saying you do not have the problem pictured in that link then go ahead and try it.
Old May 16, 2012 | 07:14 AM
raverx3m's Avatar
thats what i was looking at
but all mine (snail pieces are mounted same way)
what if td-44u is same ad single cam non vtec position?
i do have a z1 motor that i havent looked at so im gonna check that later today and my LS as well
Old May 16, 2012 | 07:17 AM
Muckman's Avatar
Moderator in Chief
I would just swap the guts over to the proper housing.
Old May 19, 2012 | 04:20 PM
raverx3m's Avatar
ok so it seems i accumulated alot of crap and about 6 distributors
i couldnt look at the 2000 LS dizzy cuz i didnt want to take it apart
update in teh first post.
Old May 19, 2012 | 04:21 PM
zombiehuntr's Avatar
Lol. Why do all that when you can go to a junkyard and and get another for cheap
Old May 19, 2012 | 05:09 PM
raverx3m's Avatar
what you mean?
i dont know what junkyards you have there but local yards remove distributors before it hits the yard( shops go there and strip all the good parts before they put it out in the yard)
Old May 21, 2012 | 01:22 AM
In Louisiana junkyards only remove the gas tank and the battery before the car is put n the yard. Other than that, they are put out as complete running cars. I've brought a gas can and jump box to the junkyard before and had cars running to make sure the part I needed is good.
92d15b7
Feb 23, 2011 10:37 AM
lilsicsoul
Jan 22, 2009 09:39 PM
Lmgrcivic
Jan 18, 2005 02:29 PM
