Rear CTR Seats Direct Bolt in?
i dont know if you can call it bold on, but you need to swap the metal frame from the ek9 to yours because its not the same. the way it attaches to the car is the opposit.
for the bench, on mine, the tabs that secures it to the car didnt line up. not sure if it because theres a diff between 97-98 and facelift models, but it was exactly the same cusion and there is no gaps on the side, just those tabs. Iit looked good that way, i ended up using one ziptie to tuck it real good. im not really using the back seat on this car...
remove yours from your car and you will see what im talking about. is a 90min job if you take your time and do it right
Eran
20
Mar 8, 2013 11:28 AM
