speedometer dont work
Old May 13, 2012 | 03:50 PM
poor_Type_caR's Avatar
Default speedometer dont work
I got a eg hatch with a Gsr swap. I just got a new speed sensor and my speedometer still doesn't work. I tried 2 sensors and 3 clusters...anyone help
Old May 13, 2012 | 04:45 PM
EsotericImage's Avatar
Retired Moderator
Default Re: speedometer dont work
http://techauto.awardspace.com/vss.html
Old May 13, 2012 | 07:46 PM
dunkingmofo's Avatar
Should have a check engine light on, get the code and see what it says.
Old May 13, 2012 | 08:59 PM
Originally Posted by EsotericImage
I have a Gsr tranny and block...the code that CEL is throwing is 14 which is the IAT. The vtech also doesn't engage too. I think its because of the speed sensor but like i said, I got a new and it still doesn't work...is it possible that I could wire it straight to the ecu? If i could, can I get a diagram of the wiring or just how to wire it? Thanks
Old May 13, 2012 | 09:09 PM
jbpnoman's Avatar
Illuminated CEL means no VTEC. It not engaging has nothing to do with the VSS.
Old May 14, 2012 | 04:22 AM
Retired Moderator
mostlikely the plug that plugs into the VSS. they corrode over time. I just replaced mine and my speedo is back in action.
Old May 14, 2012 | 12:13 PM
ok. i tried wiring the vss to the ecu and now the middle wire (yellow/blue) to power and its not sending any fuel? for it to send fuel, i need to wire it to the battery and then unplug it everytime so my battery doesn't drain out. i'll try a new plug and see how that goes too.
Old May 14, 2012 | 05:50 PM
Emerica459's Avatar
go to a junk yard and cut a few connectors with wires to replace the connector end on the harness along with a few inches of wire. I found mine was corroded badly and that fixed it. Theres no need to run a new wire from the vss to the ecu if you just have a bad end.
Old May 23, 2012 | 06:56 PM
Got new connectors and it still don't work. Idk any more
Old May 23, 2012 | 07:18 PM
cluster thats about the only thing i can see that it can be
Old May 23, 2012 | 08:41 PM
Former User's Avatar
As code 17 is not thrown, check whether the wire running between the VSS plug and cluster/speedometer is broken.
Old Jun 6, 2012 | 01:44 PM
Does anyone know to speedometer pinouts on the cluster? I want to check if there is any voltage going through..
Old Jun 6, 2012 | 02:16 PM
The VSS speed signal wire runs to B2 (Yel/Blu wire) in the cluster. Check for continuity (not voltage) from B2 in the cluster connector to the Yel/Wht wire terminal in the VSS connector.
Old Jun 7, 2012 | 04:37 PM
Ok...I checked b2 and there is power going through. Question is, wherecan I find the other end?
Old Jun 16, 2012 | 09:44 PM
Still having problems, it won't work...Idk any more...plz help
Old Jun 16, 2012 | 10:08 PM
villc713's Avatar
Your wiring harness may be bad. No speed sensor means no vtec!
Old Jun 17, 2012 | 09:57 AM
SiRCiviC94's Avatar
take it apart piece by piece play with the spring clean it all as much as you can put it back together check voltage at the clip i got around 3v. very finiky sensor. I couldnt get a continuity reading but my leads were kinda broken ...
Civic361
Transmission & Drivetrain
May 31, 2014 11:09 PM
chrisquin23
Sep 15, 2010 06:36 AM
Ej2009
May 5, 2009 02:17 PM
Sil84
Jul 16, 2008 09:01 AM
dthug
Aug 17, 2006 11:29 AM
