98 Spec ITR vs Edelbrock 4730
Old May 13, 2012 | 03:31 PM
three pac's Avatar
Default 98 Spec ITR vs Edelbrock 4730
Hi Guys,
i can get both cams which one do you guys recommend ??
Setup is :
B18C block, with Manley rods, B18B piston, B16 Head, Supertech springs and retainer, Ferrea 6000 series valve, Victor X, 68mm TB, Top turbo mani, PT 6766 turbo.
I want to run the cams with stock cam gears for now and later on want to degree de cams if needed..
Hope to get some help from my fellow HT users
Thanks
Old May 13, 2012 | 04:17 PM
yungkhmer's Avatar
Default Re: 98 Spec ITR vs Edelbrock 4730
GSC turbo cams..
https://honda-tech.com/forums/forced-induction-16/gsc-turbo-cams-vs-01-itr-cams-better-spool-30whp-gain-3042127/
Old May 13, 2012 | 06:40 PM
Turbo-LS's Avatar
With that large of a turbo i would recomend skunk2 pro1's the gsc cams are specifically designed for mid sized turbos up to say a 6262. You can also contact power division and have cams made or DDtech camshafts and get a custom profile to best suit the application
Natural Aspirations
Jan 19, 2011 05:01 PM
fusion645
Sep 20, 2010 05:29 AM
R THIS
Aug 12, 2004 12:03 PM
Charlie Moua
Jul 23, 2002 12:11 PM
