Rear trailing arm bushing question
Hi,
I made a small oops thinking the rear trailing arm bushing for a 95 integra were the same as a 00 Civic Si. In an attempt to upgrade to an energy suspension bushing I noticed they require the use of the OEM spacer piece from the old rear trailing arm bushing.
Much to my chagrin the 95 Integra bushings use a smaller diameter spacer piece
Here's picture of what I mean:
Can you buy this center piece? I tried googling it, but not knowing it's exact name I didn't find anything.
Does anyone have any used EM1 rear trailing arm bushing they want to part with? I'll buy them
Sounds good. I have the proper instruments to remove the rubber - hacking and slashing with an utility knife and then finishing it off on my drill press with the proper wire wheel did the trick on the other one. PM me your email and I'll send payment.
Thanks!
Thanks!
will do, I am going to check in the morning and make sure there are no hidden costs.
A little box should be plenty to send them.
LandeZak
10
Nov 13, 2014 07:52 AM
RAB
Nov 23, 2004 09:35 AM
