95 civic sedan - all guages not working on civic?? help
ok my guages, turn signals, clock and door open noise stoped working recently... at first i though it was just the gauges that stooped working so i changed it and no luck but the weird thing is on the gauge cluster the SRS light is still on and the check engine light doesn't come on anymore even when it loads ecu at initial start up. is there like some relay or fuse that powers all of them or something. i checked all the fuses and there all perfect none r blown.. im thinking of taking my dash out and changing the harness. does anyone have any other suggestions?
What vehicle? If you've checked the fuses (to incl. the under-hood fuses), pull your ICU and plug it back in, make sure it's seated firmly. Check that all plugs are seated properly on the front and back of the fusebox.
every fuse is good i checked them all.. my friend said something about a relay that powers the gauges and etc.. i didnt check the fuse under the hood. and its a 95 civic sedan
19Honda91Sedan
17
May 10, 2020 01:20 PM
BlackYoshi
20
Mar 27, 2009 07:49 PM
1SickHb
Oct 26, 2005 08:49 AM
