Help!! 93 Civic CX with B16 SirII swap into 93 Civic SI question
Old May 12, 2012 | 09:05 PM
Jdmswagg247's Avatar
Default Help!! 93 Civic CX with B16 SirII swap into 93 Civic SI question
Hey i'm new to Honda Tech.. been looking for an answer for my question but can't find answer... I have a rusted 93 Civic Cx with a b16sirII... i plan to swap the engine from that car to a 93 Civic Si hatch... Will it swap directly or do i need to get different engine mounts? Any thing else i might need to change like axles?? Thanks.. someone at least guide me to the right path.. i figure this is kinda rare to swap a b16sirII from a CX to a SI model.. so please if there's things i need to change.. please let me know
Old May 12, 2012 | 09:17 PM
beecee18's Avatar
Default Re: 93 Civic CX with B16 SirII swap into 93 Civic SI
Look at both of the cars next to each other..................
Now go do the right thing,
that is use common sence, and your good judgment!
Old May 12, 2012 | 09:20 PM
Default Re: Help!! 93 Civic CX with B16 SirII swap into 93 Civic SI question
i heard the Si model differed from the cx model though
Old May 12, 2012 | 09:21 PM
plus the cx has a sub harness, should i jus use the si harness?
Old May 12, 2012 | 09:22 PM
r_Senik's Avatar
yea, with different motors, breaks, ect...
but use common sense...they are the same car...so just swap everything over.
Old May 12, 2012 | 09:41 PM
alright thanks guys.. really appreciate.. i guess searching and reading lots of info got me confused..
Old May 13, 2012 | 06:00 AM
94EG8's Avatar
Seagull Management
Use the Si engine harness, but other than that swap everything (axles, motor mounts, shift linkage, etc over from the CX.
Old May 13, 2012 | 05:21 PM
K thanks... What a/c bracket do i need if I want to keep a/c? Becuz the civic cx didn't have a/c.
Old May 13, 2012 | 05:25 PM
redlinexd's Avatar
del sol vtec (b16) or crv i believe
Old May 13, 2012 | 05:38 PM
94EG8's Avatar
Seagull Management
Yep, although I can't remember if you can use the CR-V bracket on a B16A due to it's lower deck height (it definitely works on any other B-series swap)
Old May 14, 2012 | 08:02 PM
Ok... I was planning on gettin 93 civic si hatch but the seller backed out and now I am getting and 94 civic ex coupe... Is there any difference in the engine bay or would it be a direct swap from civic cx?
Old May 14, 2012 | 08:10 PM
jbpnoman's Avatar
The EX and SI both had factory optional ABS, but beyond that, they should be the same.
Old May 14, 2012 | 08:41 PM
r_Senik's Avatar
they are the same.
bly87993
May 12, 2012 09:14 PM
94sisol
Nov 14, 2007 05:15 PM
red civic standard
Feb 11, 2002 10:04 AM
b18c-93
Oct 4, 2001 09:30 AM
