95 Civic/B16a swap - 15A ECU fuse blowing
Old May 11, 2012 | 11:06 PM
68-22cx7's Avatar
Default 95 Civic/B16a swap - 15A ECU fuse blowing
My car suddenly dies. The 15A fuse for the ecu at the fuse box blows up all the time. What will cause my fuse to blow up since it was running fine. I tried another known good stock P28 ecu and still blows up the fuse. Any inputs?
Old May 11, 2012 | 11:10 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 15A fuse at ECU blowing
Do a search next time. Common problem.
Fuse 15 TSB
Old May 11, 2012 | 11:47 PM
68-22cx7's Avatar
Thanks dawg! This will work on 95 civic with a B16a motor?
Old May 12, 2012 | 03:39 AM
HondaPartsHero's Avatar
Technical Hero
No that fuse has a few circuits on it. ECU, IACV, EVAP Purge, injectors, and 02 heating element. First make sure you didn't swap the EVAP and IACV connectors. IACV should be blue/yellow stripe and yellow/black stripe. If they are correct unplug each one of the above sensors one at a time and see which one when unplugged doesn't trip the fuse then you could your issue.
Old May 12, 2012 | 03:52 AM
The Grumpiest
No. You should have listed that car info in the first post (per the rules) and it was my fault for answering without having it.
Applies To: 1996–99 Civic
Old May 12, 2012 | 07:00 AM
Former User's Avatar
Correct. Thread title edited to include information---->
For future reference, you MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Joshb152
Oct 9, 2015 09:10 PM
Karben
Jun 29, 2014 05:43 PM
liquidrider
Feb 16, 2010 05:00 PM
NazVil86
Dec 16, 2006 10:41 AM
SIK IN DA HED
Oct 27, 2002 08:42 PM
