Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2006 Civic Cyl 1 Mis fire- ALL 4 white tips
Old May 11, 2012 | 07:02 PM
falk1306's Avatar
Icon3 2006 Civic Cyl 1 Mis fire- ALL 4 white tips
Noob here.
OBD II code: P301
2006 Civic w/ 148,000 miles. fresh Denso Iridium plugs at 101,000. therefore only 50,000 miles on new plugs. One owner. As of 5-11-12 Fresh oil change, Coolent within operating range.
from the research on white tips i have found the following: coolent (fins not working properly,low), headgasket, leaking, low oil, low octane.
Anything you DIY or mechanic can help out with?????
Thanks!
-z
Any suggestions for 2006- up models>???
Old May 11, 2012 | 07:03 PM
falk1306's Avatar
Default Re: 2006 Civic Cyl 1 Mis fire- ALL 4 white tips
https://picasaweb.google.com/1059540...74654341588610
pic of plugs
Old May 11, 2012 | 07:04 PM
falk1306's Avatar
is this still within normal operatiing range? specifically color wise?
Old May 15, 2012 | 08:37 PM
fiveten's Avatar
can you feel the misfire? what happened prior to the miss? first plug looks a little dark with buildup... try and swap the coils around and see if the misfire changes cylinders.
Peteypablo17
Feb 17, 2013 04:46 AM
milkwasabadidea
11
Aug 29, 2011 08:08 PM
axionm1k
Jul 17, 2008 05:02 PM
cadet
Nov 30, 2004 06:32 AM
dc4drewH
Dec 28, 2003 07:11 AM
