FS: Piping, Exhaust, Downpipe, Mounts, Catch Can, LS, GSR
I have quite a few parts I need to get rid of I just took mostly everything out of storage so I will add better descriptions as I go here is pictures for anything specific please ask.
Mild Steel 2 1/2 inch u bend on 3 inch radius $35 each
Aluminum 2 1/2 inch u bend on 4 inch radius $45 each
Mild Steel 2 1/2 inch Straight pipe $15 per ft
Stainless Steel 3 inch straight $25 per ft
MISC 2 1/2 Aluminum Intercooler piping $125 for 6 pieces
MISC 2 1/2 Aluminum Turbo side pipe with 50mm BOV Flange $50
Turbo Paper Gaskets $3 each
38mm metal wastegate gasket $10 each
T3 metal gasket $15
Oil return flange with 5/8 hose end $25
Water Fittings and lines for ball nearing turbos $25 for both
2 1/2 inch t bolt clamp $5 each
5 bolt doownpipe flange gasket $15
2 bolt exhaust flange gasket $15
Brand New Hasport EF Hydro Trans Mount and Actuator. Never Mounted and includes all hardware this is just the trans mount $200
H22 Post Mount $35
Innovative H22 Mounts for EF chassis with actuator $250
EG Radiator Stay $10
EG, EK, DC Battery Tie Down no bolts $5
DC Radiator Stays $10
Single Cam 2 bolt post mount $15
MISC T Brackets $35 each
Innoavtive B series Mounts fOr EF Chassis $125(driver and rear mount only)
Dual Gauge Pod $20
Triple Gauge pod made for eg where heater control goes $15
Resistor Box with plugs $35
B18 DA LS Injectors $45
Aeromotive Fuel Filter $65 no element
Clamp for aeromotive fuel filter $10
OBD2 IAT Sensor $25
MISC push lock fittings $5 each
Radius arms with heim joints one end were made for innovative traction bar to clear h22 $100
98 LS Head with Intake manifold and Cams $150
B18 Stock Breather Box $15
B18 Alternator Brackets $25
B18 Windage Tray $25
B18 Oil pick up $15
B18 Crank pulley $45
98 Acura Integra LS Auto Engine Harness $75
B18 Water Tube with thermostat housing $35
Honda/ Acura Oil sandwhich $25
10ft hose NEW $44
3 -10 90s NEW $65
3 -10 straights NEW $35
1 -10 90 USED $15
1 -10 Straight USED $8
2 -10 UNIONS USED $30
CATCH CAN WITH 1 -10 fitting and 1 5/8 hose end fitting $100
Eagle GSR Big Bolt Connecting Rods used $250
Rear dum brakes with energy trailing arm bushing and earls ss brake line with e brake cables and extended studs the studs look a lil messed up but still work fine $125
MB Products Fiberglass CRX Rear Bumper $125
Innovative EK B Series Cage and Mount $125
EK Trans Mount Braket $35
Bosch 044 used with -8 or -6 fitting and mounting clamp $185
Flowmaster 3 inch muffler $75
H22 Blue Top Valve Cover $75
H22 NGK Spark Plug Wires USED $30
Chuck
310-977-1201
T3 metal gasket $15
H22 Post Mount $35
Dual Gauge Pod $20
OBD2 IAT Sensor $25
B18 Oil pick up $15
10ft hose NEW $44
3 -10 90s NEW $65
1 -10 90 USED $15
Chuck
310-977-1201
T3 metal gasket $15
H22 Post Mount $35
Dual Gauge Pod $20
OBD2 IAT Sensor $25
B18 Oil pick up $15
10ft hose NEW $44
3 -10 90s NEW $65
1 -10 90 USED $15
T3 metal gasket $15
H22 Post Mount $35
Dual Gauge Pod $20
OBD2 IAT Sensor $25
B18 Oil pick up $15
10ft hose NEW $44
3 -10 90s NEW $65
1 -10 90 USED $15
