Sprint Lowering Springs
Old Oct 13, 2002 | 12:36 PM
ayacht's Avatar
Default Sprint Lowering Springs
Sprint is an American outfit producing aftermarket sport springs for lowering. Does anyone have experience with these springs? Are they any good?
Also, can any of you who have a 1.5" dropped Accord display or send me pictures. I would like to see how much of a drop it makes. My car rides really high and perplexed to its normalcy.
I am in process of getting Koni Sport (Yellows)
[Modified by ayacht, 3:47 PM 10/14/2002]
Old Oct 13, 2002 | 09:29 PM
ratherbewalking's Avatar
Default Re: Sprint Lowering Springs (ayacht)
ive never heard of sprint. i wouldnt go cheap on springs or struts with any car. id go with a semi stiff spring and adjustable struts. (eibach pro kit:1.75 drop, and kyb agx struts) i havent had any probs with that setup. althou my friend has neuspeed springs with kyb non-adjustable struts and his ride is too soft
Old Oct 14, 2002 | 04:02 PM
urbanlegend21's Avatar
New User
Default Re: Sprint Lowering Springs (JDMAccordBoy)
is it a progressive or linear spring rate? and what size are they?
Old Oct 17, 2002 | 08:04 AM
ayacht's Avatar
Default Re: Sprint Lowering Springs (urbanlegend21)
Sprint declare the springs are progressive and the best on the market. Not too much detail about rates and such. Questionable?
Old Oct 17, 2002 | 08:21 AM
carolinaACCORD's Avatar
i have driven a 240sx with sprint on it, not too bad a ride. they had about 5k miles on them.
Old Oct 17, 2002 | 09:01 AM
New User
Default Re: Sprint Lowering Springs (carolinaACCORD)
progressive spring rates means the top of the spring is a lower weight than the bottom of the spring so it takes 100 lbs of pressure to compress the top coil but takes 250 lbs of pressure to compress the bottom coil, it isn't the best setup for performance, just a comfortabke ride
linear springs mean the rate is is consitent throught the whole spring, so it tkaes the same amount of pressure to compress the top coil as it does the bottom
Old Oct 17, 2002 | 05:33 PM
MestizoRacer310's Avatar
Questionable?
VERY. I run them...the dark blue ones, but I'm trying to decide on replacements.
Old Oct 19, 2002 | 03:20 PM
do you really think theyre gonna tell you that theyre garbage, or are they gonna tell you that they are the best thing for your car?
[Modified by ratherbewalking, 11:09 PM 10/20/2002]
Old Oct 20, 2002 | 10:54 PM
dfaulkner's Avatar
Default Re: Sprint Lowering Springs (ratherbewalking)
I'm using Sprint springs (2.25 drop) and Tokico Blues. It's a good drop, rides great also.
HondaBear
Sep 6, 2011 08:05 AM
lacking vtec
May 27, 2006 07:18 AM
Rancid_949
Suspension & Brakes
Dec 6, 2005 03:41 PM
Ben-VTEC
Jun 16, 2003 02:36 AM
Julian
Jun 2, 2002 10:48 AM
