timing questions (i need serious replys please)
I have a mini me in my ef running obd0
d15b1 block z6 head crx si intake manifold pr3 ecu
It starts but barely accelerates and I have to keep my foot on the gas to keep it alive its weird
I have all the timing marks aligned but I'm open for suggestions
Can anyone give me pointers with pics possibly good solid info to get this car up and running properly
thanks
thanks
you can't use the legs onthe dist. unless you use a y8 head. use a timing light to set the timing. pay no attention to the legs of the dist. edit, you're not using the z6 dist. are you? different tooth count inside. you have to use a obd0 dist. so that is why the legs on the si dist. wont line up with the z6 head.
ComputerJLT
Jul 18, 2004 08:51 PM
