Starting (fuel) problems
91 dx with a D16A1. Fuel pump not kicking on. Engine will turn over and fire and even run for a minute with starting fluid. Does that sound like the relay could be the problem or should I go straight to the pump?
It's the pump. I tested the relay, works fine. Tested the harness, works fine. Even put a wire on the harness to bypass the relay, still no fuel pump. The pump is shot.
When my relay went bad, my motor would turn over with the starter just fine. If I sprayed carb cleaner in the DPFI throttle body, the car would sputter and run for a second. I had 6V to my fuel pump, not 12V. I replaced the relay and the car fired right up.
I would have to side with SStupid. The main relay has plagued a many of Honda owners and with some of these cars running past 20 years old...these little boogers are failing.
I have had the very same thing happen to me and others I know. I would change that first being that it is easier to get at. Just my $0.02
oresama
31
Jan 19, 2025 10:47 PM
