Can I use a electric CSS with my stock cluster and cable?
Old May 10, 2012 | 12:09 PM
dannyb18c's Avatar
Default Can I use a electric CSS with my stock cluster and cable?
I just swapped in a JDM type r motor and hydro tranny into my 88 EF hatch. Do I need to get a cable speed sensor? Or can I somehow make the electronic vss work with my stock cluster and speedo cable? If I have to get a cable driven vss where would I get one?
Old May 10, 2012 | 12:46 PM
91 EF DX's Avatar
Default Re: Can I use a electric CSS with my stock cluster and cable?
To use the electronic vss you will have to swap the cluster
Old May 11, 2012 | 12:30 PM
dannyb18c's Avatar
Where can I purchase a cable speed sensor?
Old May 11, 2012 | 01:40 PM
4drEF's Avatar
Keyboard Humorist
What is a Cable Speed Sensor?
There are two standard options.
1) Swap out your cluster and used an electronic VSS that mounts in the tranny.
There is no cable drive for this - just wires.
2) Keep your stock cluster. This has a pulser mounted on the back of the speedo where the cable assembly plugs in. The other end of the cable assembly goes into the gear drive at the tranny.
Old May 11, 2012 | 02:04 PM
Yell88CRXsi's Avatar
or...
Option 3) get a gear drive from a 90-91 Integra with the PS fittings.
But 4drEF is right, there is no such thing as a cable speed sensor.
If memory serves me, the reason I use option 3 was that the D series tranny gear drive fit the B series tranny but then the stock CRX cable was too short to plug in correctly.
I used my stock cluster for years and years this way until 4 years ago when I did the UK cluster swap which also uses a cable. Works like a charm.
I made a small oil reservoir (from a 93-95 civic clutch) and "T" fitting to connect and lube the Integra gear drive just so my PS fittings were not open to air and trash.
RACEPAK
Nov 9, 2023 07:24 AM
ohaileo
May 9, 2017 10:41 AM
goldenhatch13
21
Nov 10, 2008 10:51 PM
^MikeG
Oct 10, 2004 07:00 PM
SpeedMonkeyRacing
Jun 2, 2004 09:40 AM
