d16z6 head d16y7 block idle problems!! 1000 to 2500 rpm
Old May 9, 2012 | 02:35 PM
turbomikeg88's Avatar
Default d16z6 head d16y7 block idle problems!! 1000 to 2500 rpm
hey honda tech, i just installed a d16z6 head (rebuilt and machined) to my d16y7 block (vitara pistons, stock bore, block guard) and once is started it up it was idling at 3000 rpm, then i started it up again it fluctuates idle between 1000 rpm and 2500 rpm. i did found a vacuum leak coming from where the intake manifold meets the head and since i was using an oem d16y8 intake manifold gasket i figured that was the problem so i purchase a d16az6 intake manifold gasket and installed it and it is still doing the same thing. i have an edelbrock performer x intake manifold but it was from my y8, would that make any difference? thanks in advance
Old May 10, 2012 | 05:00 PM
AKHAN420's Avatar
Default Re: d16z6 head d16y7 block idle problems!! 1000 to 2500 rpm
Try replacing or cleaning the iacv
onlinmrine
Feb 10, 2022 12:17 PM
spiffy_civic
18
Nov 28, 2011 01:20 PM
Vtec4me
Jun 30, 2006 09:32 AM
DarknessJ
Jul 2, 2005 06:07 PM
