EM1 ls v-tec wont start!!!!
Old May 8, 2012 | 07:51 PM
Fugly123's Avatar
Icon3 EM1 ls v-tec wont start!!!!
Hello this is my first post!
my car will not start, it will turn over but wont start.
we have Check all the plugs and wires they all have spark.
there is fuel, I checked and cleaned all grounds.
checked all the fuses, jumped it, re timed it.
the only other thing is that the radiator and fan are not in it yet i just go new ones. I don't think that would cause this but I don't know.
any help would be awesome!!!
Old May 8, 2012 | 07:59 PM
turbohatch96y7's Avatar
Default Re: EM1 ls v-tec wont start!!!!
Didn't mention if you checked compression.
Buy a gauge and check.
You need compression, spark, fuel,and timing.
Old May 8, 2012 | 08:20 PM
Fugly123's Avatar
we did not check that because i could not buy one today. tomorrow ill try that. thank you!
Old May 8, 2012 | 11:16 PM
civickiller's Avatar
i would timing
Old May 13, 2012 | 07:56 AM
based13's Avatar
Is it out of gas, completley serious, same problem has happened to me turned out my fuel Gage was stuck and I was completely dry.
Old May 15, 2012 | 02:53 PM
EGyoke's Avatar
[QUOTE=based13;47334769]Is it out of gas, completley serious, same problem has happened to me turned out my fuel Gage was stuck and I was completely dry.[/QUOTE
Add gas. If that doesnt work. Check your compression. That would be my guess. Lastly would be timing. It could be off slightly. Double and triple check it. I had it off by just a tooth and it wouldnt start.
Old May 15, 2012 | 03:01 PM
Eleazar's Avatar
check your ecu and make sure you have the right harness you never know , i had the same problem before everything worked it had gas good compression in all four. It would turn but not start ..in the end i swapped out the engine harness and car started up with no problem
nandito
Nov 9, 2011 08:27 PM
Boosted_CRX_507
Oct 9, 2008 02:35 PM
eagle459
Sep 1, 2008 03:06 PM
SergeS2K
Dec 22, 2006 02:13 PM
ToiletFetusSushi
Sep 30, 2004 09:12 AM
