b16 bolt ons
Old Oct 13, 2002 | 10:54 AM
97 BB6's Avatar
Default b16 bolt ons
I have a d16z6 right now with aem cold air intake, dc 4-2-1 header, high flow cat, and greddy evo exhaust. I am thinking about maybe swaping in a b16 in march and i am wondering if all or if any of these parts will bolt on? and I was also wondering where is the best place to order a motor from. Sorry for all the questions. thanks.
Old Oct 13, 2002 | 11:16 AM
stockegsix's Avatar
Default Re: b16 bolt ons (Tenzo Racer)
youre probably gonna have to extend the b-pipe of the exhaust, and the cat should be okay. youre going to need a B-series header, so that means you can kiss the DC goodbye, about the intake not really sure if it will, maybe. i suggest look at the one made for the b16a and compare your intake to it.
try these
hondamotorsonline.com
jdmhondaparts.com
recycler.com
thepartstrader.com
good luck with your swap.
Old Oct 13, 2002 | 11:28 AM
redline201's Avatar
my aem cai from my d16z6 fit my jdm b16a
id go b18c if i was you
i went from a d16 to a b16
still not enough power in the low rpm
[Modified by redline201, 3:29 PM 10/13/2002]
Old Oct 13, 2002 | 08:54 PM
97 BB6's Avatar
Default Re: b16 bolt ons (redline201)
thanks for the help.
I had thought about a b18c1 but i had a friend who did one in his civic and it looked sort of awkward and he still wasn't that fast. I was just thinking that even though the b18 will fit, that a b16 is the best bet because it is a civic motor and it will be less expensive. What do you guys think the price difference would be between the two?
Old Oct 13, 2002 | 08:56 PM
slowEJ6's Avatar
the B18C doesnt look awkward in a civic engine bay....at all.
id go B16A if i was planning on FI and was moreso strapped for cash. otherwise, B18C1.
Old Oct 14, 2002 | 11:12 PM
97 BB6's Avatar
Default Re: b16 bolt ons (slow ej6)
i have also been thinking about ls/vtec. I found that the ls motor is cheaper but how much would it be to get the b16 head on there. I have always thought that it would be sort of cool to do this. What do you guys think, pros/cons?
Old Oct 15, 2002 | 12:00 AM
Honda-Tech Balla's Avatar
Team Purple
ls/vtec sucks *****...their reliablity rate SUCKS *** too,r/s ratio is terrible, a perfect rod/stroke ratio is 1:75:0, and a b16 motors r/s is 1:74:0 making it almost perfect...
the b18c vs b16a2 will cost you about 900 more (if you go to HMO atleast)
Old Oct 15, 2002 | 12:32 AM
ill phil's Avatar
Default Re: b16 bolt ons (HondaRacer2681)
LS/Vtec's do not suck ***** if built right and if done so, R/S is not a huge concern.
B16's are cool, I have one and it is fun, but from a drag racing standpoint more torque is needed and the extra $900 for 1.8 to start with is worth it IMO.
Old Oct 15, 2002 | 02:13 AM
lilxvtecxpwr's Avatar
is this coming from 1st hand experience?
Old Oct 15, 2002 | 11:18 AM
97 BB6's Avatar
Default Re: b16 bolt ons (zzZZzzleeperCX)
where would be the best place to get a b16 at? I have seen my friends end up with some crappy running motors and I don't want that to happen to me also.
Old Oct 17, 2002 | 02:20 PM
Skunk_it's Avatar
The best place to have this done is at Lehmans in Ukiah Ca. come ready with the cash and we'll have it done in less then a week.
Old Oct 17, 2002 | 02:22 PM
Skunk_it's Avatar
No honda motor presents enough power in the low end, although a b18c1 will beat out a b16 the difference in low rpms is not great if any. both engines our top end.
Old Oct 17, 2002 | 02:25 PM
-Whitey-'s Avatar
Default Re: b16 bolt ons (GS-Right)
you can reuse the cai, cat, and exhaust
Old Oct 17, 2002 | 02:36 PM
nsxmatt's Avatar
The Greddy Exhaust Will work, the AEM intake will work but it's 2.5 dia. and the B16 uses a 2.75 intake. I got mine for a 99-00 si and it works fine. Header is gone, sorry.
Any engine importer can get B16's. Be sure and get the 92-95 SIRII engine with hydro tranny. The more complete the better.
The B16 is a fine engine if your on a budget and i'm running the same or better times than GSR swaps with my B16.
Old Oct 17, 2002 | 03:06 PM
Patrick's Avatar
Default Re: b16 bolt ons (nsxmatt)
You guys are talkin JDM b16's which are cheap, but if you wanna pass smog you would need a USDM b16 which is gonna run you about the same as a b18c, unless you find one for cheap (how I dont know). Go for the b18c its a good engine and will give you a better start and be easier on your wallet if you go n/a. My car should be at the low 14's and be into high 13's when I get my cams and intake manifold, then even faster when I swap out the pistons in about 6 months. I cant wait to kill some cocky guy in his stock SS (from a roll of course).
ReDHaTCH94Si
Apr 1, 2007 09:35 AM
Walshie
Jun 29, 2006 10:20 AM
slimcivic95
Aug 31, 2004 04:28 AM
Gonzo_SiR
Aug 15, 2003 06:19 AM
fsarfino
Mar 8, 2003 10:37 AM
