OBD0 B20A5 Starting Issue
Old May 7, 2012 | 10:11 PM
StaticFire450's Avatar
Default OBD0 B20A5 Starting Issue
Problem: Car does not roll over, fuel pump does not engage, Dash Indications not working(Some are)
I know: Ignition switch works great, its not that. Motor is not siezed. Starter works great.
What happens: Key 'ON' = Battery light comes on, Relay click. No CEL, Brake, Door, Nohing except Battery light(Or high beams if I have them on). When you hear the click of relay, The Battery indication light brightens x10. Also, When you click over to 'ON' the ECU flashes 1 time, really fast, barely noticable. Try to start it, Nothing... I think the only thing that happens is a light on the A/C unit that is green, shuts off.. which is normal I am pretty sure. Thinking my Civic did the same thing. But when you turn the ignition to 'OFF' the ECU flashes again, just as fast. Ill post a link to a Video on my FB of it. Its night outside, but... If you look closely you can see the red flash and hear my work the ignition.
http://www.facebook.com/photo.php?v=381343915237299
If the video dont work due to friends issue, lemme know. I can figure something out.
Assumptions of problem: Fried ECU, Bad Gauge Cluster, Bad fuse box??? Im not sure what to think..
gritzo
Nov 4, 2017 06:51 AM
Alex_S
Dec 22, 2013 08:50 AM
LST2
Nov 9, 2007 02:45 PM
90LSpimpin
Oct 6, 2004 10:06 PM
all_motoref9
May 27, 2004 12:57 PM
