Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
1998 Odyssey Key Stuck
Old May 7, 2012 | 01:14 PM
ronaldbmm's Avatar
Icon3 1998 Odyssey Key Stuck
Key is stuck in the ignition switch of my 1998 Odyssey. The wheel lock is not interfering, it is in park but the key will not turn to release. I have noticed an increased pressure when turning the key from I to II with a more definitive "click." I can't leave the keys in the ignition. Please help.
Old May 14, 2012 | 10:09 PM
wes wagon's Avatar
Default Re: 1998 Odyssey Key Stuck
Still stuck? I have 1998 as well, but I haven't had this problem... yet. I did have a similar problem in an older Accord though. Anyway, I'm not sure if it will help you to know this or not but here ya go:
There is a "Key Interlock System" in the Ody, which uses a lock/unlock solenoid to either allow or disallow key removal depending on the position of the "Parking Pin Switch". Your problem could be (or probably is) in one of these components. Basically, when the shift lever is in park, there is a pin that must turn off the pin switch deactivating the solenoid.
I have the service manual here and could help you troubleshoot more if you still need it.
Old May 21, 2012 | 08:26 PM
evil_ryu's Avatar
They are known for this you would need to replace the ignition
RecklessEJ
Sep 11, 2011 03:06 PM
pinggoy
Nov 25, 2007 07:04 PM
GregT
Acura TL, RL & ZDX
Dec 24, 2006 07:13 PM
nowind
Oct 22, 2006 10:17 AM
gbarrsh
Jan 29, 2003 08:31 AM
