At what point do you need a bigger fuel return?
Old May 7, 2012 | 09:44 AM
LightningTeg's Avatar
Community Builder
Default At what point do you need a bigger fuel return?
Looking to go E85 here soon. Going to be running a Walbro 400, Aeromotive regulator and my PTE 1000's @ 50psi. Looking for 550whp
When does one need to run a larger return line?
Old May 7, 2012 | 12:03 PM
DC4KiD's Avatar
Default Re: At what point do you need a bigger fuel return?
In for some info as I'm curious myself.
Old May 7, 2012 | 03:09 PM
sanman000719's Avatar
i making 757whp on a stock return. i wont tell you its not affecting me, but its doing its job for now
Old May 7, 2012 | 03:31 PM
Muckman's Avatar
Moderator in Chief
When you have 70psi on the rail at idle and you cant turn down your Weldon regulator anymore. Thats when the return is a restriction. Until then dont worry about it.
Oh and 1000cc's will max out around 450 on E85.
Old May 7, 2012 | 03:33 PM
Community Builder
With a Walbro 400? I've heard of that number for 255's but I was reading threads yesterday with people making upper 500s on PTE's
Old May 7, 2012 | 03:56 PM
Whiterice-gsr's Avatar
what if u block the return for extra pressure?
Old May 7, 2012 | 04:26 PM
MR.johnson's Avatar
you are wrong.
and when you cant turn the pressure down at idle its time for a bigger return.
Muckman's Avatar
Moderator in Chief
Sure the pump is capable but the injectors dont have the volume. You can squeeze another 25hp out of them if you crank the pressure to 100psi. I have two Walbro 255s at 65psi base (80psi) at 100% duty @ 8700rpm 450whp with ID1000s.
Edit: Mr Johnson, whats the correct answer - 120psi rail pressure?
Old May 7, 2012 | 04:29 PM
MR.johnson's Avatar
http://answers.yahoo.com/question/in...4185410AAtzeyg
read that, you would then have a returnless fuel system.
Old May 7, 2012 | 04:35 PM
MR.johnson's Avatar
Sure the pump is capable but the injectors dont have the volume. You can squeeze another 25hp out of them if you crank the pressure to 100psi. I have two Walbros 255s at 65psi base (80psi) at 100% duty @ 8700rpm 450whp.
here you go. these are all cars that have 1000cc and a 255. dyno charts are in the video.
a few of my friends will be chiming in with their cars and dyno graphs as well.
http://youtu.be/OjkhkXs2118
http://youtu.be/JKG1pTWn6D4
here is shawty22's car, single 255 and 1000cc tuned a few weeks ago.
Old May 7, 2012 | 10:36 PM
mycarslow's Avatar
my pte 1000s made 525 at 95% duty
Charlie Moua
Mar 22, 2013 05:17 PM
baphomet
Oct 7, 2003 10:08 PM
turbo Si
Mar 16, 2003 10:28 AM
justinCO
Jun 7, 2002 08:55 PM
IgniteTeg
May 29, 2002 11:08 PM
