Worlds Quickest & Fastest True Street RSX- 10.412142mph
Old May 7, 2012 | 07:32 AM
KeseK24RSX's Avatar
Default Worlds Quickest & Fastest True Street RSX- 10.412142mph
I know before you mention the PYRSX, that car is considered on Outlaw class car due to tire size & turbo size. His tire are bigger than 24.5" tall max, & his turbo is bigger than a 67mm max. Our car has 24.5x8.5x15in Tires & a 62mm turbo & weighs 2700lbs w/ a full interior. Well within the True Street Class Rules.
We took the car out to a 1/4mile track for some more testing.
10.41@142mph
Video:
http://www.youtube.com/watch?v=YGR7T49AHL8
KMOD Performance stg.4 turbo Kit w/ 6266 Turbo Upgrade
& FIC 1100cc Fuel Injectors, 340 Fuel Pump(returnless system)
KMOD K24 Engine Specs:
70mm TB
RBC IM
K20a2 Cyl. Head
Supertech Springs/Retainers
TSX Cams
Stock sleeves(87.5mm)
11.0:1 Wiseco Pistons
Eagle Rods
KMOD Oil Pump
Trans:
6-Speed Type-S
Synchrotech Carbon Synchros
5.06 Final Drive
2700lbs Full Interior Street Car
-Marquis
-KMOD Performance
Greensboro NC
Old May 7, 2012 | 09:16 AM
Gunmetal_B20_Hatch's Avatar
Default Re: Worlds Quickest & Fastest True Street RSX- 10.412142mph
what fuel and power level?
Congrats, 140+ is really moving for a street car. Looks like it should still be very drivebale on the street with the TSX cams... what clutch?
Old May 7, 2012 | 09:35 AM
TheShodan's Avatar
Moderator
70mm TB
RBC IM
K20a2 Cyl. Head
TSX Cams
Eagle Rods
KMOD Oil Pump
Trans:
6-Speed Type-S
5.06 Final Drive
-Marquis
-KMOD Performance
Greensboro NC
thank you for showing the proper way of using the gearing to accelerate the car by using a shorter final drive and not falling for taller gear is better argument. Sure, you can hear the turbo longer, but that doesn't mean one is going anywhere any faster.
KeseK24RSX
May 25, 2012 08:55 AM
Atlas
Dec 26, 2003 05:50 PM
mcs2000si
Feb 28, 2003 08:29 PM
