Rear Crossmember Removal
Old May 6, 2012 | 07:20 PM
EF8DayDreamer's Avatar
Default Rear Crossmember Removal
the member is cracked too big to weld. How do i remove the rear crossmember where the rear motor mount sits.
Old May 6, 2012 | 07:53 PM
beansandrice's Avatar
Default Re: Rear Crossmember Removal
I don't remember those being removable aside from cutting out. Have you had it looked at by a fabricator?
Old May 6, 2012 | 09:10 PM
BIGef's Avatar
there will be 2 bolts on each side
Old May 6, 2012 | 09:26 PM
delsol92's Avatar
yup what he said, they are either 17 or 19mm bolts and becareful when unbolting it will fall and **** your face up
Old May 6, 2012 | 10:14 PM
BIGef's Avatar
its a 17mm. what i usually do is support it with a jack.
Old May 8, 2012 | 05:40 PM
is it only two bolts ?
Old May 8, 2012 | 05:48 PM
BLU CIVIC's Avatar
Track Advocate
4 bolts, undo outer tie rods and lower control arms
you can find a shop manual online
Old May 11, 2012 | 03:54 PM
thanks
Old May 11, 2012 | 08:00 PM
ef yu's Avatar
dont forget the steering rack. had to replace mine because of a crack as well.
brewerkz
Honda CR-V & Element
Jul 23, 2017 07:52 AM
cehcivic15
14
Jun 18, 2012 12:50 PM
looxs
Mar 25, 2006 09:37 AM
monotone485
Oct 21, 2003 02:00 PM
juicy.koreans.suck
Jan 22, 2002 01:56 AM
