anyone know why my car looks like this??
Old May 5, 2012 | 04:45 PM
crx_975's Avatar
Default anyone know why my car looks like this??
i have 16's with 205 40 16 tires and theres a ugly *** gap from the fender/bumper to the front wheels
Old May 5, 2012 | 05:04 PM
4drEF's Avatar
Keyboard Humorist
Default Re: anyone know why my car looks like this??
Because something is wrong with the suspension.
My guess is, by the white fender that doesn't match rhe car, that the car was involved in some sort of accident.
The LCA, steering knuckle, radius rod, and crossmembers need to be checked out.
Old May 5, 2012 | 05:07 PM
sstupid's Avatar
10 Year Member
There's no way that car drives straight. Bent LCA at least.
crx_975's Avatar
that was my first guess too, but it wasnt like that with the original steelies
Old May 5, 2012 | 05:11 PM
crx_975's Avatar
car drives straigh btw, like i said, the wheels dont look like that with the steelies. ill try to find a pic
Old May 5, 2012 | 05:19 PM
4drEF's Avatar
Keyboard Humorist
Doesn't matter if you have a pic or not.
Changing a wheel doesn't do that.
Something is wrong with your suspension.
Old May 5, 2012 | 05:21 PM
92teginsc's Avatar
yeah and its not safe to drive it at all at its current status.
Old May 5, 2012 | 05:58 PM
Vagitarian's Avatar
lol he makes it sound like he puts the steelies on and it automatically centers up
Somethings bent man
Old May 5, 2012 | 10:07 PM
CW-ITR's Avatar
Judging from the big gaps between the windings of the spring, I would say the the engine was taken out getting ready for a swap to be dropped in or the shock is stuck and not being compress by the weight of the car.
Old May 6, 2012 | 06:26 AM
just-ef-it's Avatar
check to see if the radias arm bushings are shot, or the bolts are loose at the front crossmember. or someone smoked a curb and like previous posters said, your suspension is fukkkked! if thats the case, replace wheelbearing,knuckle assembly, lca, inspect the strut and mid cross member for cracks, kinks or bends
Old May 6, 2012 | 06:34 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Yes radius rods are what I'd check first, namely if the bushings are missing and/or bolts are missing/loose.
Can you hold the wheel itself and move it forwards/backwards while car is secure on jackstands, or is it stationary?
Old May 6, 2012 | 08:53 AM
pimpwagon's Avatar
looks like the camber on the rear wheel is waaay positive as well.
Old May 6, 2012 | 01:39 PM
ef9lsvtac's Avatar
what motor is in it.....my lsvtec ef snapped the front traction bar and thats what my wheel looked like....DO NOT drive it you will **** up axels, struts balljoints
Old May 6, 2012 | 07:58 PM
beansandrice's Avatar
Looks like its doing the shuffle dance
Old May 7, 2012 | 06:49 AM
crvtectim's Avatar
Looks fine to me. Rock on.
Old May 8, 2012 | 04:28 PM
dohccrxsi's Avatar
Jeez.... Your CASTER is way out...
Radius rods don't cause that at all, not with caster like that, I bought a CRX in Georgia years ago that had the same problem, stop leading this guy in the wrong direction if you don't know what you're talking about, there's enough of that on this site already.
To sum it up, You have a bent / twisted upper control arm (If the LCA was bent, Your car WOULD NOT DRIVE STRAIGHT, PERIOD), First, Measure from hub center to hub center front to back (The very inside of the wheel where the hole is for the wheel cap), Find out how far off your driver side is from your passenger side (This is for orientation after you've replaced your bent UCA to check how much your wheel has moved forward and a to give you a good idea if you've got anything else bent), Remove the Upper Control Arm on your driver side and inspect it around where the ball joint is mounted inside of it on the end, If it looks twisted or cocked to one side, replace it, this should solve your problem, for the record, caster is not adjustable on these cars, if your caster is ever out on an ED/EE/EF Chassis, You have something bent, simple as that, You can pretty much look at the Upper Control Arm on the passenger side with the wheel off and compare it to the driver side if you're lazy and don't feel like pulling it off.
And for the record, My caster was out just as bad as his is, and My car drove straight for 6 months and never caused any issues with my axles, this is not going to crucially damage your car, its just going to look like total hell and probably wear out your ball joints a little quicker, a lot of drag racers used to run offset caster on cars to make them hook up better and straighter, ask some of the old guys around your town that were into muscle cars back in the 60's / 70's if you don't believe me.
Good Luck.
P.S. Just by looking at that picture, You can see that the Upper Control Arm is twisted back, forcing the spindle back towards the firewall, Hence you wheel's caster placement.
Old May 8, 2012 | 04:31 PM
dohccrxsi's Avatar
And Also, Changing to 14"/15" Steelies will make it seem like the caster isn't off, But I assure you it still is, the wheel diameter profile on the smaller sized rim is what makes it appear less drastic, been there, done that.
Old May 8, 2012 | 06:55 PM
Hidenplanvew's Avatar
Caster
shm91
26
Feb 6, 2013 10:58 AM
LSteggyguy
Feb 4, 2012 09:35 PM
slowpoke414
Jun 7, 2004 05:42 PM
Opie
May 20, 2004 09:47 AM
Echo7847
10
Mar 30, 2003 03:52 PM
