fuel pump, injectors, or dizzy?
Old May 3, 2012 | 01:34 PM
spades614's Avatar
Default fuel pump, injectors, or dizzy?
Ok so i just got mt car running againg 92 civic sohc zc bottom y8 head on stock p28....
At first my fuel pump wasnt prime when i turned the key, got a new main relay problem fixed and now when i drive it sputter and pops when at normal engine operating temp from like 2 1/2 - 4k rpm ..... but if i floor it ,its like goes back to normal. Idles good when cold but low and a little rough when cold ..... what do you guys think it could be
Old May 3, 2012 | 10:13 PM
newlude8657's Avatar
Default Re: fuel pump, injectors, or dizzy?
egr?
Old May 3, 2012 | 10:22 PM
Carbon deposits in the EGR valve can cause it to stick open a bit and cause a rough idle. If it is bad enough, the engine will stall out when you slow to a stop
Old May 3, 2012 | 10:23 PM
civickiller's Avatar
timing good? double checked with timing light?
Old May 4, 2012 | 07:45 AM
ThePunisherPnc's Avatar
1st check ur timing..make sure its top dead center when u do it. after that check your dizzy, if that fails then it may be the injectors or faulty map sensor
Old May 4, 2012 | 08:11 AM
BryanM.'s Avatar
Resident Gearhead
^ Like they said, check the mechanical and ignition timing.
Any chance the TPS and MAP connectors are switched around?
Is there a check engine light?
Y8 head doesn't use EGR, and a P28 wouldn't know what to do with it either.
Old May 4, 2012 | 02:53 PM
spades614's Avatar
Yeah i was about to say no egr valve.... all timming marks match up on point .alo checked ignition timming with timming light ... no check engine i didnt switch the tps and map i remember the wire colors for the map ...... ground are clean as well
B18B_EJ1
Dec 28, 2012 09:13 AM
crave13k
Sep 2, 2011 11:33 PM
zpizzle07
Aug 20, 2008 09:36 PM
maxamusprime
May 25, 2007 08:54 AM
88 rex
17
Aug 18, 2005 10:05 AM
