Which O2 is the primary on 1st gen b16?
Old Oct 13, 2002 | 12:13 AM
Monty's Avatar
Default Which O2 is the primary on 1st gen b16?
Took my car out for its first 40 miles yesterday. The car was running really good and was so fun in 3rd and 4th gear with the J1 tranny. Im definately happy with it (for now)
Towards the end of my drive I got code 1 which is primary o2 sensor. Does anyone know which one is the primary? Im thinking closest to block (reads first) but not sure.
Thanks for any help
Old Oct 13, 2002 | 04:01 PM
Booger's_Rex's Avatar
Default Re: Which O2 is the primary on 1st gen b16? (Monty)
if you are looking at your engine it is the one on the left. the secondary is on the right. the primary goes to c16 on ecu and secondary to c8. hope this helps
Old Oct 13, 2002 | 04:25 PM
-16V-'s Avatar
Default Re: Which O2 is the primary on 1st gen b16? (Booger's_Rex)
Im new to this stuff but how do you know your ecu is throwing codes???
Is the light blinking in the ecu and that tells you the code??
I'm lost
Old Oct 13, 2002 | 04:51 PM
Default Re: Which O2 is the primary on 1st gen b16? (1991_jdm_sleeper)
yes the blinking light on your ecu tells you the code.
Old Oct 13, 2002 | 08:11 PM
Monty's Avatar
Cool thanks. Primary being the white plug. Turns out it was never connected all the way. Snapped it in and bye bye code.
Hopefully no more for a while. Time to start driving it to work and back.
Old Oct 14, 2002 | 02:52 PM
n2o914drb16's Avatar
did ya reset your ecu too.......light may be out but th ecode will still be in the ecu's storage......and next time your light comes on you may think the o2's bad....when it's not......just a thought.....
Old Oct 14, 2002 | 03:27 PM
Monty's Avatar
Default Re: Which O2 is the primary on 1st gen b16? (n2o914drb16)
yeah i pulled Hazard fuse for 30 seconds, then started her up with no codes. Let it idle 5 or so, then rolled. Is this proper?
Old Oct 14, 2002 | 06:17 PM
MADEINIRAQ's Avatar
technically the car should be warmed up and then pull the hazard fuse.. but you did it fine
draxxus07
Sep 29, 2005 11:35 AM
denshu
Jan 11, 2004 07:46 AM
Charlie Moua
Jan 13, 2003 08:32 AM
