94 accord, no power
Old May 3, 2012 | 04:18 AM
will-239's Avatar
Icon2 94 accord, no power
hi, i'm hoping someone out there has had some experience with this issue. first, it's a 94 accord ex, v-tech 2.2,problem is no power under load, starts fine, idle's fine, revs fine, put it in gear and it's fine until i press the gas pedal,then it just boggs down, if i feather the gas i can get it up to speed, when i do this it goes through all gears well. new fpr, well cleaned egr,new cat converter,new spark plugs(gaped properly).only trouble code i get is for the knock sensor, i will replace this also,will a knock sensor cause this? any help is welcome, thanks
Old May 3, 2012 | 09:53 AM
Anythingbtcivic's Avatar
Default Re: 94 accord, no power
try your o2 i had some bogging down problems and it was my o2 sen.
Old May 3, 2012 | 10:22 AM
jdmcertified909's Avatar
hell yeah you bet its your knock sensor. its not retarding or advancing your timing thus making it bog. do you have access to a scope? or advanced scanner that shows live data?
Old May 5, 2012 | 05:16 AM
Lost Again's Avatar
A 94 with a knock sensor code, can you tell more please.
Old May 6, 2012 | 09:28 PM
nus_dogg's Avatar
will-239, these F22B1 SOHC VTEC does not come with a knock sensor. You probably read the code wrong.
Old May 10, 2012 | 09:07 AM
will-239's Avatar
trying 02 sensors, and looking into knock sensor, thanks for all the input
76 camaro car
Nov 21, 2015 09:46 AM
redlobster
May 16, 2009 05:45 AM
Dmata
Apr 26, 2004 06:42 PM
00 FBP ItR
Aug 10, 2003 02:38 PM
