stock dizzy vs remanufactured. timing
Old May 2, 2012 | 08:52 PM
raverx3m's Avatar
Default stock dizzy vs remanufactured. timing
i swapped in a stock P30 dizzy while troubleshooting no spark. and had it on for a week.
set timing with the p30 dizzy and it was almost dead in the middle with correct timing.
today i swapped back the BRAND NEW remanufactured dizzy(not sure what brand i got it from craigslist) and i had to rotate it all theway towards firewall to get to middle mark.
nothing else changed just dizzy swapped..
is there something inside the distributor that also rotates to have that much offset between p30 and remanufactured one?
Old May 4, 2012 | 05:36 PM
raverx3m's Avatar
Default Re: stock dizzy vs remanufactured. timing
bump
Old May 5, 2012 | 03:47 AM
grumblemarc's Avatar
The Grumpiest
Couldn't answer your question directly from experience. All I've ever seen on the forums is to buy OEM when dealing with distributors. This would be one of the reasons why.
Old May 5, 2012 | 07:36 AM
raverx3m's Avatar
well when i bought it i was told its a rebuilt oem dizzy but turned out its not. i didnt know better.
Old May 13, 2012 | 09:27 PM
raverx3m's Avatar
anyone can take a wild guess why it would be offset by so much?
Old May 13, 2012 | 10:20 PM
civickiller's Avatar
i read somewhere about swapping 2 wires for a sensor in the dizzy can cause retarded timing.
this was over 10 years ago so i only remember that, sorry
Old May 21, 2012 | 01:28 PM
raverx3m's Avatar
so is there anything that can be done to the remanufactured dizzy to get it to have proper timing in the center of the instead of rotated all the way?
Old May 21, 2012 | 01:54 PM
compare the wiring between the 2 distributors
Old May 21, 2012 | 01:58 PM
famous323's Avatar
you did nothing to the mechanical timing?
Old May 21, 2012 | 02:38 PM
raverx3m's Avatar
it looks like they are identical i did not do anything to the wiring.
stock P30 dizzy was in dead center of the bolt hole at 16 degrees.
i put the remanned one and had to hammer it with my wrench to get it to 16 degrees.
nothing else was changed.
what parts areresponsible for the timing inside the dizzy?
there are 3 pick up coils in it can anyone tell me which one does what?
crappyshifting
Jul 18, 2013 09:00 PM
zenon8890
11
May 3, 2009 08:37 AM
r1de4life
Sep 11, 2007 11:41 PM
StlSupra
10
Jul 27, 2005 05:48 AM
sloweh3
Oct 3, 2003 11:22 PM
