would this work? brake master cylinder and booster combo on an ef?
Old May 2, 2012 | 06:27 PM
949's Avatar
949
Default would this work? brake master cylinder and booster combo on an ef?
i was curious if a brake master cylinder and booster from 2001 honda accord V6 will fit and work on an EF 91 chasis with a skunk 2 intake manifold?
Old May 3, 2012 | 06:20 AM
949's Avatar
949
Default Re: would this work? brake master cylinder and booster combo on an ef?
...also the reason im choosing this model car for its brake m/c and booster is because the lines actually are on the same side as the ef brake lines and the threads are the same on the ABS m/c. that means that we dont need to move the hard brake lines too far nor rematch the rear line size. both are 10mm
Old May 3, 2012 | 09:05 PM
delsol92's Avatar
wont work
Old May 3, 2012 | 09:55 PM
949's Avatar
949
Originally Posted by delsol92
wont work
could you expain more.
Old May 4, 2012 | 01:30 AM
Stunna MIKE's Avatar
just use a 90-93 integra NON abs BB and MC.. i just did this on my rex.. no need to move any lines or reflare or anything...
Old May 5, 2012 | 07:30 AM
949's Avatar
949
thank for the reply.
i still have questions.
90-93 integra non ABS.
which model integra?
is this a 1 inch?
i am planning on buying these combo new. its not that expensive at kragen or local autoparts store. im not familiar with integra's thats why i ask.
Old May 5, 2012 | 02:53 PM
its a 15/16".. and any model thats non ABS.. which I would think would be only specific RS models..
I just got a BB, MC and front disks from a DA.. rear disk and the 4040.. I've probably only spent about 200 on the lot.. used ofcourse, but I bet your BB and MC are going to run you over 200 new.. just look on the classifieds
Old May 5, 2012 | 02:56 PM
4drEF's Avatar
Keyboard Humorist
If you want stock lines and 15/16 then just use the 90/91 Civic Sedan EX MC.
It will bolt right up to the stock booster and has the lines in the right place.
If you want 1" then go with the DC ITR MC and booster.
Booster bolts right up and brake lines screw right in.
Only mod needed is to bend one of the lines to the other side of the MC.
Old May 7, 2012 | 06:59 AM
949's Avatar
949
thanks brotha!
i feel adventurous,
im down to get the DC ITR MC and Booster.
just to make sure im on the right track, what are the years for the DC ITR (integra type-R)?
Old May 7, 2012 | 10:11 AM
949's Avatar
949
with the 1" will the rear line be the same size?
i have read that some one inch will be 12mm and the front will be 10mm
Old May 7, 2012 | 10:24 AM
4drEF's Avatar
Keyboard Humorist
Both are the same size.
It's only the JDM 98~2000 ITR.
I had one from a 98.
Old May 7, 2012 | 09:31 PM
949's Avatar
949
integra 2000 type-r
in this picture the master cylinder looks like the lines are on top and towards the inside. my lines are both on the outside.
my 91 civic
Old May 8, 2012 | 07:44 AM
4drEF's Avatar
Keyboard Humorist
Quoting myself
Just needs a cheap pipe bender tool and project complete.
Old May 17, 2012 | 06:23 AM
949's Avatar
949
im not sure if you notice that both of the lines are on the wrong side on the integra vs the ef pic i have here.
BIGef
Sep 25, 2014 10:47 PM
cripemaster
Jun 15, 2010 08:28 PM
CapnKrunch
18
Aug 30, 2007 05:38 AM
lollypopking
Jan 16, 2005 09:51 PM
ISELLRIGHTHANDDRIV
10
Aug 9, 2003 03:38 PM
