A/c mode control wont work
Are you referring to the motor control that operates the actuator door? You should be able to remove the kick panel, disconnect the wire harness and remove 4- 10mm screws (most are phillips head as well, a stubby scewdriver gets at them easily), gently pull straight away, taking care not to bend the delicate actuator arm it connects to behind.
I've seen a few of these (mine included) go out, usually on the dual climate controlled models the driver side. The common failure is the gear teeth on the main input shred off, i.e., the gears bind- and usually make a clicking noise under the dash when the air control is engaged.
Dunno if you already knew all this, as a younger mechanic I'm learning as I go, so figure if I can save you a couple minutes hopefully it helped.
I think the going rate on majestic honda, etc is $43 or so for the unit.
my car has the same problem.
even though im okay with other cars, im new to honda. few questions. hope you dont mind.
1) is there any fuse for mode motor alone?
2) where is the exact location of mode motor ? driver side ? behind central consol panel ?
3) could you pls post some pics of the removal and mode motor itself ?
4) what is the part number for mode motor ?
Sinner
Jan 23, 2006 07:45 AM
Zoso1977
Nov 6, 2004 10:57 PM
