Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
A/c mode control wont work
Old 05-02-2012, 04:11 PM
stoneyr's Avatar
Default A/c mode control wont work
cant get it to go from the dash to the floor on a accord ex 05 with navigation system!
Old 05-03-2012, 11:09 PM
ryder_kid's Avatar
Default Re: A/c mode control wont work
Are you referring to the motor control that operates the actuator door? You should be able to remove the kick panel, disconnect the wire harness and remove 4- 10mm screws (most are phillips head as well, a stubby scewdriver gets at them easily), gently pull straight away, taking care not to bend the delicate actuator arm it connects to behind.
I've seen a few of these (mine included) go out, usually on the dual climate controlled models the driver side. The common failure is the gear teeth on the main input shred off, i.e., the gears bind- and usually make a clicking noise under the dash when the air control is engaged.
Dunno if you already knew all this, as a younger mechanic I'm learning as I go, so figure if I can save you a couple minutes hopefully it helped.
I think the going rate on majestic honda, etc is $43 or so for the unit.
Old 05-04-2012, 05:04 AM
stoneyr's Avatar
yeah i think that is what im talkin about i took the center vent panel off and i could see a lil flap that controled the air flow of what way it went to dash or floor. so I'm guessing that i would have to remove the navigation system out to get to all that?
Old 01-21-2013, 04:27 AM
aslamvm's Avatar
my car has the same problem.
even though im okay with other cars, im new to honda. few questions. hope you dont mind.
1) is there any fuse for mode motor alone?
2) where is the exact location of mode motor ? driver side ? behind central consol panel ?
3) could you pls post some pics of the removal and mode motor itself ?
4) what is the part number for mode motor ?
willy65000
Honda Fit
21
02-13-2012 08:49 PM
TEAM EoR
04-12-2008 11:26 AM
Sinner
01-23-2006 07:45 AM
Zoso1977
11-06-2004 10:57 PM
Quick Reply: A/c mode control wont work
