Engine Noise after Header Install
My friend has a 00 Civic si and after he installed his headers his engine started making a weird sound. Any ideas? Search didnt turn up anything, maybe i didnt search hard enough
First check to see if the bolts are torqued correctly, then retorque them after he drives for a while. Also sometimes the increased airflow goes through a poor seal at the header/cat converter where the donut thing is, which happended to my car too. I just bought a new donut gasket and the noise went away.
you question is vague, be more specific... what does the wierd noise sound like?
[Modified by lilxvtecxpwr, 3:56 PM 10/13/2002]
and also what make of header did he install?it the bolts on the header flange are comming loose from the block then use some loc-tite and that should stop that. one or two drops is all you need.
or maybe your civic really is haunted. if you start to hear a knocking sound then they want to be let out of the hood.
[Modified by tek_civic, 10:11 PM 10/13/2002]
