What exactly does MAP sensor do?
Old Oct 12, 2002 | 10:05 PM
1990hondaHF's Avatar
Default What exactly does MAP sensor do?
I'm looking for a more complex answer then..."detects manifold pressure"...thanks all!
Old Oct 12, 2002 | 10:21 PM
MADEINIRAQ's Avatar
Default Re: What exactly does MAP sensor do? (1990hondaHF)
tells computer how much vacuum the engine has.
[Modified by madeiniraq, 7:34 AM 10/13/2002]
Old Oct 12, 2002 | 10:24 PM
the DR.'s Avatar
Default Re: What exactly does MAP sensor do? (madeiniraq)
tells computer how much vacuume the engine has.
that and.. uses this reading to calculate the load on the engine
Old Oct 12, 2002 | 10:25 PM
Aphrodavid's Avatar
tells the ECU the negative presure(vacuum) inside the intake manifold so the ECU knows how much fuel to dump
[Modified by DX-R, 11:38 PM 10/12/2002]
Old Oct 12, 2002 | 10:32 PM
MADEINIRAQ's Avatar
Default Re: What exactly does MAP sensor do? (DX-R)
tells the ECU the presure inside the intake manifold so the ECU knows how much fuel to dump
in stock form it only reads vacuum...... you would need aftermarket program like hondata to read boost or pressure.
um.. yeah
[Modified by madeiniraq, 7:33 AM 10/13/2002]
Old Oct 12, 2002 | 10:38 PM
Aphrodavid's Avatar
physics my friend. negative pressure = vacuum
Old Oct 12, 2002 | 10:40 PM
MADEINIRAQ's Avatar
yeah ok
Old Oct 13, 2002 | 12:19 AM
mos's Avatar
mos
Actually the stock one can read +pressure also.
Old Oct 13, 2002 | 07:05 AM
Default Re: What exactly does MAP sensor do? (mos)
Thanks. I've always wanted to know. Now I do!
Old Oct 13, 2002 | 08:51 AM
Wes V's Avatar
I could be wrong, but as I understand it (and being REAL exacting);
It gives a signal to the ECU based on the relationship of the manifold pressure (vacuum)and atmospheric pressure. The key point here is the atmospheric part of it. That's what would cause a different signal output if you were at high elevation, but had the same manifold pressure.
From what I've read, the stock unit will read a small amount of boost. It's around 5 pounds I believe.
Old Oct 13, 2002 | 09:03 AM
PhatOptimo's Avatar
Default Re: What exactly does MAP sensor do? (Wes V)
MAP=Manifold Absolute Pressure
Old Oct 13, 2002 | 09:25 AM
pelotudo's Avatar
yes. It reads ~3 psi. Therefore, when you add FI, you need either a. Checkvalves or b. Missing link in order to trick the MAP in to thinking you're staying under 17.7psi (I think, or is it just 3; and the original 1 ATM is not counted?). It can read positive, and that's what will cause it to throw a CEL (Over ~3 psi).
jB
black_ek
Sep 3, 2008 09:42 PM
EJ8 GSR-T
Feb 19, 2007 09:11 PM
The Weather Man
Aug 13, 2005 10:45 AM
thashadow
Jun 12, 2002 11:35 AM
