11" Corrado Rotors on EG?
I heard that you can use 11 inch VW Corrado G60 rotors and Accord Wagon Calipers with EX or Integra knuckles on an EG Civic. Anyone else heard of this or seen it done?
not sure if you know that corrado rotors dont have lugnuts sticking out... they have bolts you have to put in... (my vw friend has a 1990 g60)
FYI, they can be replaced with studs
Does anyone know if the depth of the rotor would match up with the accord caliper directly bolted on to the correct knuckle. What does the fastbrakes kit include?
Yes, I have this. You'll need a ring, I forgot what it was called though, that goes over the lug nut area.
Also, make sure you get the 4-lug patern.
Without the fastbreak adopter kit, whatever caliper you use will not clear the rotors though.
6ghatch
14
Jul 28, 2005 03:41 AM
hatchdrvr
May 28, 2004 05:00 PM
