Distributor Seal/O-ring - Can I find them Locally?
Old May 2, 2012 | 03:38 AM
t0p_sh0tta's Avatar
Default Distributor Seal/O-ring - Can I find them Locally?
Morning, the title says it all. My F22B's dizzy is leaking, and I'd like to try and source replacements locally. Any suggestions?
Old May 2, 2012 | 05:34 AM
h22a2JZGTE's Avatar
Default Re: Distributor Seal/O-ring - Can I find them Locally?
not sure if your looking for the internal seal or the outside seal...but heres the outside seal i bought recently b/c i had a external leak awhile back..if you have an internal distributor oil leak you'll need to make a run to the stealership and/or find an online oem type parts distributor bc not too many places sell it
http://www.ebay.com/itm/Honda-Accord...133bc9&vxp=mtr
Old May 2, 2012 | 08:42 AM
t0p_sh0tta's Avatar
If I'm pulling it out, I might as well do both. Thanks for the help.
Old May 2, 2012 | 09:47 AM
Bad_dude's Avatar
Take the cap off and if there's no oil in the dizzy, don't worry about the internal bearing seal. The o ring for my car, 90 Accord can be had at the local dealer for $1.98. Easy to do. If your valve gasket needs changing, do it at the same time. In order to get that price, you need to go to honda.com and order e-parts and pick up at your dealer. Easily done. I did mine 4 years ago and never leak since. Put a little gasket material around the outer portion of the dizzy for extra seal like the 4 dabs on your valve cover at the humps.
Old May 2, 2012 | 11:08 AM
holmesnmanny's Avatar
They got the internal seal at partstrain. However, these only fit on oem type distributors, not aftermarket ones, as I learned.
http://www.partstrain.com/store/?N=0...stributor+seal
What I actually did was I took the spring from the inside of this one and put it on my aftermarket seal which had a spring that was inadequate, to say the least.
kerrn
Sep 25, 2012 10:36 PM
Cameron k.
60
Sep 25, 2012 07:19 PM
mickiemagik
12
May 15, 2007 10:06 AM
sonson6
Mar 20, 2007 07:56 PM
dpkelly
Dec 1, 2006 12:53 PM
