GSP Turbo kit for RSX EP3 8thgen SI
Old May 1, 2012 | 09:46 AM
FA5_Joker's Avatar
Default GSP Turbo kit for RSX EP3 8thgen SI
Im looking to boost but im on a budget and was wondering if anyone has done one of these and how good was the oil feed and return kit and did the down pipe bolt up with no problem? how much hp did yall get out of it?
Thank You
Old May 1, 2012 | 10:09 AM
Arthas's Avatar
Default Re: GSP Turbo kit for RSX EP3 8thgen SI
GSP doesnt make the kit, they just resell it. I have a friend that used to work there, real good guy.
Oil feed will be fine, but for the return just weld a bung to the oil pan and use 5/8th" fuel hose from Pep Boys. Those AN whatever BS lines it comes with are really hard to set up and are prone to leaks. With the fuel line, just 2 clamps and youre golden.
Downpipe will not bolt on with no problem. 99% sure it will require some modification.
A lot of people are going to be nay sayers about an "eBay turbo kit" but its a great starting point for people and youll learn a lot from it. Also, you can always upgrade parts later on. The most important part is the tune though, if you dont plan on dyno tuning or using a reputable engine management system, forget about it. Just do basic bolt ons.
hybrid1990crx
Apr 18, 2010 08:26 AM
kauai96
Jun 1, 2008 06:31 PM
-16V-
Jul 8, 2005 07:31 AM
itr449
Jan 23, 2003 06:28 PM
