Crankshaft Position Sensor
Yes, it's one of the most critical components for the ecu to be able to operate your ecu. Chances are, the wiring has been damaged or just rotted away as old as it is.
code 4 - crank sensor is inside the distributor - most likely your distributor is bad, if the wiring is o.k.
90RENOsedan
Dec 21, 2009 10:14 PM
quik89
Nov 30, 2003 06:43 PM
sander
Apr 25, 2003 07:46 AM
