cut and buff on a budget
Old Apr 30, 2012 | 06:19 PM
eric587's Avatar
Default cut and buff on a budget
my friend is practicing painting and my hood had clear coat pealing so i let him try it out, he did an alright job i guess just allot off orange peel, so i want to cut and buff it but dont have much can someone tell me how to do this thanks guys
Old Apr 30, 2012 | 06:55 PM
mike703's Avatar
Default Re: cut and buff on a budget
get some water in a bucket. add 5 drops dawn dish soap. purchase 1500 and 2000 grit sandpapers. using the paper grits that i just mentioned will take a little longer to get the surface flat BUT will help to prevent you from sanding through the clear into the paint. once you get it flat with the 1500 move to 2000 and sand in only one direction. then buff, using a rubbing compound. then you can get your glazes and polishes or whatever.
Old Apr 30, 2012 | 06:56 PM
mike703's Avatar
also make sure youre using a sanding block
mike703's Avatar
stay away from edges
Old Apr 30, 2012 | 11:27 PM
gorillafart's Avatar
use the search button, thats how
Old May 1, 2012 | 05:47 PM
eric587's Avatar
thanks that was exaactally what i was looking for. Will the dish soap hurt the paint? and which compound will you recommend?
Old May 1, 2012 | 07:45 PM
joeshmo's Avatar
No, the dish soap helps to lubricate/let the water stay "slippery" longer. I use meguairs m105 and m205. If you can't find those, there are consumer grade rough equivalents (ultimate compound and ultimate polish).
Old May 2, 2012 | 08:13 AM
eric587's Avatar
Thanks guys thats exactly what im looking for. Does anyone know how to buy a good quality sanding block
Old May 2, 2012 | 08:19 AM
joeshmo's Avatar
The rubber 3m ones are alright. I have a flexible hand block that works really well for me and cost about 4$ online.
Old May 3, 2012 | 01:38 PM
eric587's Avatar
thanks for all the info ill upload before and after pictures when im done
Old May 3, 2012 | 02:40 PM
AutoBodyByJake's Avatar
B careful with the sanding block. You can burn through edges very quickly. If u want to make buffing easier finish off with some 2500 or 3000
Old May 3, 2012 | 02:41 PM
joeshmo's Avatar
When using meguiars sand paper, I find 3000 grit is a waste of time. Especially on an initial buff.
Old May 4, 2012 | 10:39 AM
VRD^don's Avatar
use 3M purple finishing film. =D no need to wet sand. less loading than wet sanding less pig tails and longer disc life.
Old May 4, 2012 | 11:01 AM
joeshmo's Avatar
Never even heard of it. I know some guys skip the wetsand and just use 3m superduty, but what is purple finishing film? Would love to see a product video or something.
Old May 4, 2012 | 12:12 PM
VRD^don's Avatar
http://3mcollision.com/3m-hookit-pur...500-30367.html
thats for the 3 inch pad, they also have it in multiple sizes.
Old May 5, 2012 | 01:56 PM
mike703's Avatar
if you read it says its for lacquer
drumminforev
16
Feb 19, 2023 09:18 PM
dagle
Paint and Body
Apr 26, 2008 11:17 PM
EK_B
Paint and Body
Apr 23, 2008 02:21 PM
cilvia
Nov 11, 2006 11:34 AM
b16greenmachine
May 2, 2006 12:16 PM
